manwithtools
Awesome job Mike. Easy to tell you enjoy a challenge. You make it look easy and those of us who know better, know it's anything but easy.
I've gotta say, for not being a gunsmith, you are sure imitating one nicely.Nice work, that's a neat looking old rifle.
My guess would be that he replaced the nut that normally holds the vice down the the jack screw assembly.
Great idea BTW.
Great job on the gun repair Mike. I have the DB that sat across my great grand pappy's lap in his covered wagon when making the Oklahoma run. Tant nuttin fancy but it sure is a cool display piece.
......Nothing like doing all of this vertical and overhead welding during the hottest month of the year.
Trade you shops for the month.... I will even throw in August & September as a bonus!
Sent from my iPad using Tapatalk Pro
Only Mike could make a $300 6/32 screw
Excellent as always bud, it looks the part perfectly![]()
Thanks Cam. That's what my son said last night, "sure glad you have that $6k lathe and $7k mill to make a .28 cent screw."![]()
I'm telling you, for guys that can crank handles, it a disease.
Great job Mike!
Only Mike could make a $300 6/32 screw![]()
I was thinking when I was reading Mike's post, why is he making a 6/32 screw? The answer of course, because he can!
Nice work as always Mike.![]()
Thanks. Trust me, that wasn't my original plan but I didn't realize a large head flat headed 6-32 screw would be that stinkin' hard to find.
Oh well, it all worked out and turned out ok.
I appreciate you taking the time to stop by and check out what I have going on.
zmotorsports said:The screw jack is actually placed right on the ledge of the vise. It was at a very slight angle but just enough to put some pressure on the part. It wasn't ideal the way I had it holding the part but I didn't have a lot of options, but I did get a chance to use my shop made screw jack so that's a plus.[emoji106]
Finallygotit said:My guess would be that he replaced the nut that normally holds the vice down the the jack screw assembly.
Great idea BTW.
Mike, there are sources for screws like that, but it might be difficult to find one in 6-32. It's pretty coarse for a #6 gun screw. Most in that size today are 6-48.
I recently had to install a tang sight on a 19th century Winchester lever action and found that they used either 10-32 or 10-36 screws. It turned out to be the latter, and I had to order a tap to chase the threads.
Two good sources for gun parts and tools are:
Brownell's www.brownells.com
Numrich www.gunpartscorp.com
You can’t expect us not to ask you to share more info about “Shop made screw jack”.
No ****, that IS a great idea!!
I don’t check in for awhile and you’re screwing around. Nice fix on the rabbit ears.
I chose to use the Teraflex large bore master cylinder but Mopar also offers one for the 2007-2011 JK model. If you have a 2012-2018 JK you don’t need this upgrade as they already have a larger bore master cylinder.
Lookin' good Mike! Those screws you made look great! Looking forward to seeing the WJ build progress.
Pat's shop and mine are 15 minutes apart and I've found that I can throw some business his way. Our homes are closer to an hour apart. I finally got to spend some time in the garage tonight as the wife is out of town with friends and not here keeping me busy getting stuff done inside the house.
I changed the oil in the mower and snowblower and put a rope and handle on a similar snowblower to mine that my neighbor gave me. He just went out and bought a new one when the recoil rope failed in the middle of our 22" weekend in April. The plug-in electric start had apparently previously failed so it was dead to him. I actually started at the electric start since I didn't have rope and a handle. I found that the plastic around the brush holders had just melted a bit and coated the commutator in gunk. Went up to the farm store and grabbed some files and emery cloth as well as the parts I needed. I was surprised the electric motor was so easy to fix. I'm happy to have 2 snowblowers now though in case the father in law needs the one he gave us back.
Have you looked at the Mopar J8 booster/master kit? I replaced my stock stuff with it when I upgraded my JKU with DynaTrac 60’s and it made a substantial difference. The master had a much larger bore than the stock unit that came off of my 2014. The combo has no issue handling the 1-ton calipers.
https://www.northridge4x4.com/part/...50-mopar-j8-master-cylinder-and-brake-booster
Nice little addition to the shop Mike! I suspect however that while it’s a nice machine, you could figure out how to get good welds out of Harbor Freight welder!
First congrats on the new toy Mike! Second all though I think I know the answer already. How come?, I do everything with .035 but totally admit it's way overkill for lite gauge work. Does switching to .025 make that much difference?
What is it Z? Looks kinda like a receiver-alignment gizamaflatch. Isn’t it missing a piece of round tube on the right about 1/4-inch off the edge? [emoji6]
Damn fine welds sir. I bought a 211 full-size auto-set a ways back and, like your sayin, I fiddle with settings less and lay nice beads more. So much different than models of old where you had to find the sweet spot for each thickness, each size wire, etc.
I'm curious as well. I do everything in .035, but have considered trying a roll of .030 to see the difference. I also need to put a better ground clamp on my Miller; mine seems to be way too sensitive to grounding.
