Enco Belt Sander Grinder Model 163-4700
torqueman2002
SE Michigan
I picked up a disc and belt sander/grinder.
Please don't tell the guys over in the Craftsman Block Grinder thread. :eyecrazy:
It looks pretty straight forward to operate, but no manual.
I like manuals. Any ideas?
I checked OWW /VM and Googled it.
Thanks.
zkling
Better for metal than most 6/12 combo units, seldom do you find smaller disks that run in the same ballpark as 20" units.
T
torqueman2002
SE Michigan
Thanks guys. $50 is a screaming deal, this is one heavy machine.
I eMailed Enco for part info, it has a couple of white metal pieces that are broken. It's usable as is, but takes some fussing to adjust the wheel's grinding table.
I hope the Block heads don't ban me for bringing home a non-Block machine. :bitchslap
dodge610
North Canton Ohio
Thanks.
Oh my lord on top of its nit a block grinder style it is made in taiwan. You sir have broken all the rules. No really nice lookin piece and looks pretty sout. :bounce:
T
torqueman2002
SE Michigan
Oh my lord on top of its nit (not) a block grinder style it is made in taiwan. You sir have broken all the rules. No really nice lookin piece and looks pretty sout (stout). :bounce:
Ya, how about that too boot!
Taiwan is turning out very decent tools/machines. I have a couple of nice Grizzley woodworking shop tools.
I do wish the US was turning out price competitive tools good quality. I like shopping 'local'.
dodge610
North Canton Ohio
Yep spell check does not catch all the mistakes. And I get in a hurry a lot of the time. On an off note still looking for a block grinder around me still no luck. My brother got my dads.
T
torqueman2002
SE Michigan
I can't help editing your post, it was part of my job before I retired. I too, am confound by spell check. ;)
About the Block - if you haven't been to the 'Block' thread, follow these links and PM me.
http://www.garagejournal.com/forum/showthread.php?p=5153283#post5153283
http://www.garagejournal.com/forum/showpost.php?p=4516788&postcount=3761
senorgarage
Have one of these same units in my shop and it looks like the starting cap gave up the ghost... Unfortunately the fluid leaked out and ate away most of the markings on the cap. I can't read the MFD rating at all and the only bit of the model number I can see is "2131". Does anyone have a manual, spec sheet, or the ability to check what cap is in their machine?
6PTsocket
Which block grinder do you have? What is the model number? They came in several sizes and variations. They all look similar. Sears Parts Direct probably would not have the value with the part number but they or E Replacements may have a usable picture to get the value from. One or both may even have the cap. The company that made the block grinders, ended up as part of Husqvarna group and some block grinder part numbers are in their catalog. Snoop around and you may find the info.
senorgarage
Oops I should have been more clear, I have the Enco 163-4700 (not a craftsman). Unless you mean this Enco was sold through sears or is otherwise the same as a Craftsman model?
T
torqueman2002
SE Michigan
OK, here you go.
This is a dual voltage wiring diagram.
Here's what I found under the cover of my Enco.
Here's the numbers from the start cap. I have found it's safe to be with in +10% of the MFD. Grainger, Amazon, etc ... will have these.
Would you happen to have an owner/operator manual?
T
torqueman2002
SE Michigan
I found a replacement start cap that should work, on Amazon for $16.18 with free Prime shipping.
PTMJ400 - Packard Aftermarket Replacement Motor Start Capacitor 400-480 MFD 220 250 Volt
Caution: Be sure you know how to safely discharge a capacitor.
senorgarage
OK, here you go.
Thank you sir! I owe you a beer or three... sadly I don't have any kind of manual either, but should i run across one i will post up!
bubinga
Torque man 2002 I noticed that V capacitor you show is marked 220 volts does the voltage not matter? If I recall correctly from my high school Electronics class or prior research the voltage would not matter but I am not sure reason for my question LMAO........................ Amen
Sent from my MotoG3 using Tapatalk
crazyorangutang8
Thanks.
I know this is an old post, but I have this sander and need to change it from 110v to 220v. Problem is the wiring diagram showing the correct motor taps under the cover is missing. I reached out to the parent company MSC, they were able to dig up the old manual for me but could not find the wiring diagram. Would you happen to have that sticker under the wiring cover?
*Edit* I see you've already posted the information in a post I couldn't see before I became a garagejournal member. I attached the owner/operator manual to that post as you had inquired about it there.
crazyorangutang8
OK, here you go.
I don't know if anyone posted the owner operator manual, but I got this from parent company MSC.
  • 163-4700.pdf
T
torqueman2002
SE Michigan
I see you have found the diagram. I had forgotten I posted it.
While searching for a completely different reason, I came across the Grizzly owners manual MODEL G1183/G1276, that is very close (maybe identical) to the ENCO Model 163-4700.
These color and larger diagrams may be helpful, also.
BTW - My sander/grinder is a beast and is very loud. I'm wondering if yours makes a lot of noise. And it really needs to be on a 20A circuit, it has tripped a 15A lighting circuit breaker.
For full size or to download manual, click on image.
Screenshot 2023-12-05 145802.JPGScreenshot 2023-12-05 145606.JPGScreenshot 2023-12-05 145718.JPG
  • g1183_m Owners Manual.pdf
