Old Wright 1" drive ratchet N-820
Nightblue
I have an old Wright N-820, 1" drive, ratchet. I need a renewal kit. I opened it up and saw that the pawl tip was damaged. I tried to flip it over to see if I could get it to work, it didn't work so well, it still jumped.
I will attach some photos.
I may have to to another piece machined.
one photo is the ratchet.
one photo shows the pawl in the flipped over position where the damaged tip is seen in the lower right area.
one photo shows the pawl removed from the ratchet with the damaged tip.
Thanks, DaveS
davethorik
Norka, Ohio
Another possible option if u have a welder at your disposal, build the damaged area up with weld, and file/machine to shape.
Nice find. Parts for a tool that age would have to be salvaged from another ratchet. I think the 44 indicate that was made in 1944. It would be a miracle to find a rebuild kit for one, but I’m sure they are out there somewhere.
I’m curious what the other numbers represent, and why one it crossed out like that.
N
Nightblue
Gents,
Thanks for the replies. My first thought was to weld and grind. I got to looking at it and thought to just flip it over. It should have worked. It was jumping teeth while loosening. It was still jumping teeth after flipping. Maybe I have a little problem with the center teeth/hub.
I do have an uncle that knows his way around a lathe and milling machine. I'll bring it to him the next time I go to WISC.
I can afford to take my time.......I have another ratchet that can handle any job, it is a snap on 1.5". It has to weigh every bit of 35 pounds.
Thanks
DaveS
bonneyman
Desert SW
Gents,
Thanks
DaveS
As my dad always said, "You've gotta have the time or the money. Since I don't have alot of money, I've gotta have LOTS of time." :thumbup:
Username already in use
Neat ratchet. I'm a bit surprised that it didn't work when you switched the pawl around. Too bad. I recently found a couple of 1in drive drive plugs for the big bertha Proto/Plomb ratchet on eBay, so that stuff is out there somewhere. Probably welding it will be your best bet.
Looks to me like some kind of department, unit designation, or inventory number for a factory setting. The old number would have been crudely X'd out and the new number applied when the tool was reassigned. That's my guess anyway.
jabberwoki
puyallup wa usa
Dave, you better post up a pic of that Snappy beast.
I love that old Wright, I found a 1946 3/4 drive at the scrapper that works like a charm once it was cleaned and lubed.
N
Nightblue
Snap On L-78 1.5" Drive Pic
I was able to find a couple of pictures on the Snap On L-78 1.5" drive ratchet. She is a beast. Enjoy. How much do you think it is worth? I believe it is NOS. I sand blasted it, it had a light surface rust. Its painted black now.
With the snap on handle.
DaveS
Shelbylex
Dave S, this is a monster! Never saw ratchet this size. Please post picture of the whole thing with something for size reference.
Not sure how much it is worth: probably at least couple of hundred for the right person. I wonder what was it used for...
bonneyman
Desert SW
Dang, why don't you try flipping the pawl over? Both the top and the bottom look the same in the pic, and I'll bet the ball and spring won't be affected by the worn tip.
Worst case I'd do as someone else said and just get some bar stack and grind/file a replacement pawl.
N
Nightblue
bonneyman, I did try flipping it over, that was the first thing I did. The ball / switch was a little difficult to move because it is shaped a little differently. To the eye, it looks like the mirror image......like I said there may be a little damage inside some of the teeth. When I get back to the States I will leave the cover off and put to work and watch what it does. I will also take some more pics of the big ratchet. I'm in West Africa at the moment.
I'll let everyone know what I find out.
DaveS
N
Nightblue
Value of Big Ratchet........ I was thinking that she should probably be worth around $500. easily. I had some wheel lugs on a large tele-handler that I needed to get off, I tried a 3/4 impact, I then tried a 1" impact (with a 3/4"air line), I then grabbed the Big Ratchet. I had to have a guy hold the ratchet, extension and the socket in place while I put an eight foot cheater pipe on the handle.......I had to put all 240lbs into it.....CRACK !! Worked like a charm.
