"The Punch"
A_Pmech
IL
Hi guys,
About a week ago I asked for ideas on pin punches in The Hammer thread. Here's the resulting prototype incorporating some of your suggestions and a few ideas of my own! Let me know what you think. :beer:
Rather than try to explain them in a post, I made a video which I think does a better job:
Also, are a few photos:
scooby074
Nova Scotia
very nice. Like the colour coding. Nice detail.
Some ideas:
What about etching or engraving the size as well?
Knurling in the area of the colour grooves might be good as long as it doesnt interfere with the handle action.
Longer pins might be a option.
What about a tapered line up pin?
jrsndman
Philly
Sweet... I broke a punch today because of the exact problem you talked about in the video.
How much?
A
A_Pmech
IL
Some ideas:
Hi Scooby, thanks for the ideas!
Etching the size and my logo is planned, possibly personalization. The etching equipment I need is in a box on a USPS truck about now! It's the same equipment used by NASA, Do-All, Boeing and a number of other companies.
Knurling isn't needed as the grooves provide plenty of grip. Knurling would also interfere with the handle action as you say.
They would come with both a short and long length pin. I sized the pins for The Punch using ANSI B18.8.2-1978, R1989. The two pin sizes, short and long, cover the entire range of "Practical Lengths" of slotted spring pins as laid out in the standard.
:beer:
That's a possibility I hadn't considered...
Shadowdog500
Down the shore
They look great. Some gunsmiths use replaceable pin punches, so you may want to tap that market when you make them. You may be aware that Brownells makes replaceable pin punches, but they don't go as big as yours.
I also like the handle.
Chris
MD11
USA
Put me down for a pre-order when you begin to accept them..
First Class!
A
A_Pmech
IL
Merkava_4 said:
Bad-***!! Love it!!
Thanks, Merk!
M900 caught a slip-up in the video. The punch body is 5" long and 1/2" in diameter. I guess wouldn't make it too long on the TV a weatherman... :spit:
As to pricing, I need to make another set and work out some machining details. I should know more in a few days and then I'll be able to price them.
BTG
Indy
:bowdown: Very Nice!!! If the price is right...I'm in. What would make it outstanding would be a nice custom-fit box for the set.
street131
West Michigan
oh man, that is so impressive. If the price was right, i would definitly buy a set. Not only is it a great idea, but just the design itself looks cool.
A
A_Pmech
IL
Do you have plans on making roll pin punch tips?
That's a possibility I'll have to look into, Tony.
Currently, the tips are ground with a slight crown to aid in centering the pin.
I've been thinking about a case. What would you prefer?
Thanks! I'll keep you up-to-date as I determine the pricing.
Basskiller said:
That is a slick setup!
Glad you like it!
Sloper0204
UT/WY
A pelican with cutouts for The Punches and The Hammer :)
Once you get pricing on these down I will be submitting my order for The Hammer and The Punch at the same time since I still need to do that :shocking:
mrb
i dont know what this is for, but I want one (price dependent of course)
autoace
Maine,USA
Like the punches, seems like a great idea, can't say as a mechanic, that I would use the handle, unless I was doing bench work.
Nice well thought idea:thumbup:
Offer different length inserts, for brake caliper pins, you need a long 2.5 inch long pin punch at times. Long pin punches are the most used by auto mechanics.
Good luck :beer:
toolfreak
Illinois
Very nice looking product but I can't see the allen screw holding the pin in place when using any force on a stubborn pin. I hope I am wrong because I like the looks and quality of them.
Shadowdog500
Down the shore
I bet the pin is bottomed out in the handle and the allen screw just keeps it from pulling forward.
Chris
X1 Mike
Flagler, Fl
If you are asking for opinions,
I would grind a slot for the set screw to seat in and also make the pins undersize. The set screw will keep the punch from galling and being impossible to remove. If I want to knock a .250 dowel out I would rather use a .245 punch.
bmwpower
Very nice. :) I love stuff like this.
Only criticism I have is I wish the punch itself could be knurled somehow, but I realize that would mess with the idea of using the "holder" and sliding in/out.
Sometimes you just don't need to use a holder (confined space, etc.) so it would be helpful if you could use it without the holder as well. Would you using the colored rings for grip?
Oh, just thought of something else.... what about a screw on/off replaceable other end of the punch? You know, sometimes people get a little over anxious with the hammer...
Just some ideas off the top of my head...
A
A_Pmech
IL
I like your thinking! :bounce:
The pin is bottomed in the handle bore, so all the impact energy is transmitted directly to the pin. The set screw there only to hold the pin in place. :thumbup:
Good luck
Thanks for your input, Autoace!
A
A_Pmech
IL
Hi Mike,
I haven't encountered any problems with the pin galling and seizing in the handle bore as the set screw doesn't make much of an indentation in the pin.
Good idea! Under-size pins are definitely a possibility for dowel pin applications.
:beer:
bmwpower said:
Very nice. I love stuff like this.
Thank you!
The rings do provide plenty of grip for holding onto The Punch. They're placed right were you grip it with your thumb and index finger, like a pencil.
While it's common practice to drive a pin punch with a ball peen and I'm guilty of it as much as anyone, best practice is to use a soft face hammer. It extends the life of the punch and avoids mushrooming out the anvil end. I like the idea of a replaceable anvil though, I may see what I can come up with. :thumbup:
A
A_Pmech
IL
Well, I haven't even set the price yet and the serial #1 set is already spoken for!
:bounce:
nissan_crawler
Wichita, KS
3 things.
First, the roll pin punch tips would be great, as mentioned. They're priceless for gun work.
Second, what about a straight 1/2" punch for the bigger work?
third, will these work with the 40/30/21/10 drill bits for drilling out rivets and snapping the heads?
These seem like a highly logical solution to punch problems. I can see where some tax money might be going.
