Sullars and JB, those little vises are cool! What is the jaw size on the Paramo No. 0?
The Jaws are 60mm matey
Setting aside the condition of the metalic surface (polish, pitting, corrosion, wear and specific alloy composition), the coefficient of friction must be largely dependent on the area of the mating surfaces. The largest factor in that is the length of thread from one end of the main nut to the other end, plus the bearing surface of the spindle head or meatball. Both of those are going to increase directly with main screw diameter (holding TPI and nut depth constant).
In practice, the TPI we see is most certainly going to decrease as screw diameter increases, because manufactuers figured this out a long time ago.
I suppose the contact suface of the bar, rod or screw enclosure (whatever means is used to keep the jaws aligned) is also a significant source of friction. Hmmm. That is probably reducable to a mostly linear measurement, as well, but independent of main screw diameter.
Believe it or not, the force of friction is not dependent on surface area, only force and the coefficient of friction. Coefficient of friction is constant, and doesn’t change with surface area.
The base on that Record is freakin huge!My Wilton Bullet 9300 dated 1976, and a 3D printed Baby Bullet i printed off a while ago.
[/url][/IMG]![]()
[/url][/IMG]![]()
Brooks 1970s Leg vice 50lbs 4.5" jaws
[/url][/IMG]![]()
Record 25 & Paramo 0 vices before and 12hrs later
[/url][/IMG]![]()
Thanks, Outlaw. In the examples I’ve seen, coefficient of friction is safely assumed to be constant where the contact surfaces are planer and gravity is the opposing force. That’s not the case here, but I would like to redact all uses of “coefficient of” in my earlier speculation. I think I committed a semantics fowl.
My purpose is to advocate the recording of screw diameter. Threads per inch on a screw without knowing diameter can no more determine mechanical advantage than the number of cogs or sprockets on a gear or wheel.
Royce, see what you've done.![]()
VA,
Yes, if I just had a little higher coefficient of good sense, this could have been stopped before it started!!!
I'm also thinking JZiggy should tote half this load, after all, it is his gadget!!!
Royce
The ratio of teeth on gears is what determines mechanical advantage, just like thread pitch on a screw, so I’m not sure what your point is.
Interesting conversation!
ZOOM
Zoomie, in the next week or so, I'll have a compiled list of Royce's and my measured applied force numbers. IMO for those vises that get measured, besides the force generated we should add:
- Handle length from the center of the screw head)
- Main screw thread diameter
- Thread pitch
- Thread type (Optional, but entertaining)
I've never had my hands on a york. Since you have thoroughly been through both. What is your take on overall build quality and design of the york vs the wilton bullet?
KM, how long did it take you to acquire all the units in the family?
VA,
Royce
- Thread pitch
quick little refurb on this 05196. dated 10 51. sadly I couldn't save the original paint under the black spray bomb. Oh well... this is the third one of these I've had... I don't see the appeal to them as to why people like them... yes they are heavy... the castings are very weak and porous. this is the first one that wasn't broken on the jaw support, but the casting imperfections on the lower jaw support tell me they are prone to breaking. jaws look minty.
What about applied force to the handle? It would seem to be a pertinent number that could vary quite a bit depending on the weight of the user.
Sorry, I'm not following; what lower jaw support? These have the "U" type jaws, so only a single support? Are you thinking Wilton? I see that all the time...
I have two of these and the only iffy part of the design IMO is the main nut backlash adjuster. One is OK, the other is broken...
AB very nice restoration job! I is that original craftsman tag that came with the vise (looks in very good shape)? And the jaws indeed minty!
I have never seen any 519x in person and based on all the previous posts was under impression that these vises are of highest quality and hence all the speculation as to who made them for craftsman as the usual suspect (Columbian) was not in general one of the higher quality vise manufacturers! To be honest hearing that this might not the case is a bit of shock!
Morning folks, need a little assistance with a vise that’s for sale as I know practically nothing about Prentiss and have been scouring here and elsewhere on the net but am running out of time so asking for a little info and guidance. The vise is a Prentiss 6” swivel jaw, and that’s all the info I have other than the picture. The markings are on top at the back of the swivel which I believe makes it an older model, possibly a #22, but that’s all I know, other than I’m questioning the base and wondering if it’s missing a swivel or is it as was when left the foundry. Oh, yeah, price. Ha ha, ok so this is the most I’ve even considered spending on a vise but I’m wondering if this is a decent price for this size with swivel jaw or not. $200-250 depending on if the stand goes with it or not so $200 I guess bottom line but have to talk to seller again to confirm. Interested in hearing some input/thoughts y’all might have. Thanks in advance. -Josh
I would be curious to what a Starrett and or Athol compared to the same jaw width Reed. These vises are in my opinion the better built vises in the States.
ABlook at the second picture on my post. the original badge was faded/worn bad. I repainted the original badge. Filled in the letters with blue paint, sanded them down, then spray painted the red area and sanded down the fine letters and outer border.
Gman, I've had three of these 519X series now. two of them have been badly broken in the dynamic jaw support ledge. one was completely cracked around the upper jaw area on the dynamic and had been braised back together that paint covered. both 51 and both of them had jaws that looked mint or hardly ever used. They are heavy as hell for a 4" vise. but the castings are very very porous. Columbian vises are lightweight ductile iron. the snobs here on GJ don't particularly rate columbians as well made vises. in the 120-130 vises Ive had, sold, refurbed, etc I've never seen a broken columbian. Ive had 204 1/2's that were dented on the dynamic jaw and had bent screws from people bashing them with sledge hammers to press in u joints and never had a crack or broken issue. Ive never seen a busted dynamic support on a columbian. the only broken part I've seen on a columbian has been a mounting hole on a swivel base which any vise is susceptible to if not mounted tight, or proper.
I don't know who made them. I originally thought Rock island based on the jaws, date stamp on the slide, tapered swivel lock, the teeth engagement on the swivel base, and the overall weight of them. but after having a couple rock islands, they are STOUT. they are not brittle like these craftsmans seem to be. there is a threaded collar on the spindle that is unique to this vise. the adjustable nut retainer is unique to this vise and a poor attempt at a reed split nut copy. I'm honestly not sold on them. the reed made craftsman might be my favorite oe so far short of my big rock island combo 543b.
here was a 10 48 date 05191 that had the dynamic completely busted on the right side tower. was braised together and completely undetectable under the paint. the jaw itself basically held it together.
