I have a 230V/1P Champion compressor that was working fine until yesterday when I drained the tank, now it won't start. I did drain it to wire in a motor disconnect (I had previously just been using the breaker), but that all looks fine. I have the two hot legs wired to L1 and L2 in the panel on the compressor, just like previously, and the ground wired to the shared lug in that panel. Both legs are getting power (123V each on L1 and L2), and I also see power at the pressure switch. I never heard a hum or a pop or anything to indicate that the motor
...(rest of original post deleted)...
EDIT: I found out that I'm not getting 240V at the output of the disconnect for some reason, so that's the most likely culprit and what I'm focusing on for now.
