TT_Vert
Basically both the tank fitting and the regulator fitting will be the same height. They are 12" apart center to center. I want to put a ball valve between the two. Does anyone make a ball valve union in 1/2" NPT? I googled but didn't find anything. I am going to have a 1" stub off both ports to get the height I need to clear the regulator to get a direct line of sight to the compressor port. I am trying to find a way to do this with swivels or some way where I have some form of a union to be able to tighten the 12" pipe. I know I could just go with a 1/2" union and something like 5" stubs but I'd really like to put a ball valve in there if possible. Perhaps there is a fitting that would work I am not aware of? I might just go w/ copper if it becomes too problematic then just cut it out if need be later. Would you guys recommend 3/4" ID for this short run or just the ID of a 1/2" black pipe?
Thanks much.
Dave
Thanks much.
Dave
To shut off the air pressure to the airline system.
