GFCI receptacle needs to be reset after power outage?
bryank930
SE Wisconsin
I have one GFCI receptacle in my garage that needs to be reset every time the power goes out or flickers from a storm or whatever.
It's the only one, and I know I should just replace it, but is this a common thing? It's a 15A Eaton, so it's not a cheapie. Strangely enough, the cheapies I have all stay on after power loss, but DO trip when I plug the GFCI tester thing in and hit the button.
So...do I have a defective GFCI?
wyliesdiesels
Modesto, CA
When you say cheap, how much you talkin?
How much was the Eaton?
I use levitons and havent had issues with them tripping.
bryank930
SE Wisconsin
Cheap as in it's a brand name, lol. Not the 20A paladins I got for $8.50 each. I got the Eaton on clearance at Lowe's for $5, but msrp is $15
bryank930
SE Wisconsin
Oh, yes, it does reset with the tester. Both the built-in test button, and the plug-in tester.
Even if I turn the breaker off, then back on (simulating a power outage), the outlet does not come back on until I press the reset button.
I may just replace the breaker with a GFCI breaker and put a standard outlet in.
nomadskidoo
iowa
I turn "Off" kitchen lite=,blows breakerACGFI ,electrician says "Normal" ,I had another Electrician check it out,needs complete rewire(Of Kitchen).$8,000 later contractor won't do anything,I can replace the $45 breaker.Sad ,New $350,000 home and they cannot FIX it! County "Inspected" this Home???
jim111
tx
Is this receptacle feeding anything else downstream that might be causing this? If not I would just change it out.
