AngryBeaver
Alright, got all the heavy rust off, and and most of the grime. Will be picking up some wire wheel attachments for my Dremel to get to the tough spots. I also picked up some evaporust, which will be nice, because the vise has already flash rusted due to the humidity. I want to gather what I need, in order to be the humidity once I evaporust the vise.
1. Vise was Originally Black correct? What paint and Primer would you recommend?
2. No painting the sliding portions correct?
3. What do I coat the unseen inside parts with, like inside slider, boiled linseed oil?
4. I have seen some leave the clamp/jaw part raw? Should i do that or paint?
5. Is the handle to be painted black too? Do I leave sliding part of the handle raw because it will scratch?
Just want to gather the supplies I need to complete.
Thanks!
k
Great score. your vise was made in the likely late 30's. there was a couple colors that were original back then like olive green or a flat black. its your vise, paint it whatever color you want.
I would not paint the handle, slide or the jaws. when i use Hammerite brand paints, they are specifically made not to use primer. they have ingredients that latch on to porous surfaces and work better than with primer. some of the rustleoum paints are this way. most guys use a quality self etching primer.
when I redo a vise, I try to paint the unsee sides if possible. if not, when i lube it up with Fluid film, it'll be fine. most weren't painted inside the slide or underneath when new and they've lasted 100+ years soo.
heres some color options for you. just depends on what you want or what you like. the craftsman (actually a reed 203-1/2) is hammerlite dark blue. the middle reed 104R is a rustoleum cobalt blue metallic, the reed 214 on the left is rustoleum hammered black and the prentiss is hammerlite mid green. the hammered blacks are more of a dark charcoal grey than actual black. the snap on wilton that is super gloss black is a rustoleum appliance gloss black epoxy paint. and the little wilton is a candy apple red rustoleum.
