The Small Liquidators Thread
victor252
Hey all,
It seems there are a slew of small tool liquidator sites that don't show up often on google searches. We've been looking at some great deals on some of these sites and here's another called Zerbee.com with deals on those Proto socket sets:
https://www.zerbee.com/Manufacturers/PROTO.aspx?keyword=Mechanic's+Tool+Set,
Looks like Alliance Supply also has the same deal. http://www.alliancesupply.com/Manufacturers/Proto.aspx?keyword=54120
6 pt version: http://www.alliancesupply.com/search.aspx?keyword=54122
A list of all the sites we've mentioned in the past couple weeks includes:
https://www.cleanitsupply.com/ (thanks mrspeed)
https://www.ontimesupplies.com/ (thanks KDoug)
https://www.rapidsupplies.com/ (thanks GMCGarage)
https://www.officecrave.com/ (thanks Ragin_Cajun)
For clearance deals on VIM tools, a supplier to some tool trucks,
https://cloud1.shopsite.com/donofish/page35.html
Please note that these small time outlets seem to have lousy categories and names for their stuff so searching the manufacturer's part number is best.
These sites have been selling some stuff at less than half what Zoro wants. So if you're shopping around, check out these sites since Google might not pull up results. Be advised, they seem to sell out quickly. Post the deal in the thread and if anyone has other sites that are similar, I'll add them to this first post.
R_einan
Eastern WA
I’ve been looking, but not finding much. I was hoping to find a deal on a 1/2 metric set, but nothing yet.
V
victor252
^^^ sorry to hear but thanks for the update.
I struck out twice on these small sites before zerbee actually had the 18pc set and shipped it. I'll take the deal off the first post.
Billbuilder
Campbell, CA
I ordered the Proto 30 piece this morning off the rapid supplies web site. We'll see if they cancel my order. I don't really need another 1/2" socket set, but for $115 I couldn't help myself.
V
victor252
So after a few cancellations, here's my haul from the various sites listed.
3/8" drive SAE from Blackhawk (USA)
1/2" drive SAE from Proto (USA)
18" breaker bar from Proto (USA)
15" 72 tooth round head ratchet from Proto (Italy)
Looks like the 3/8" drive BH USA sockets are identical to my 3/8" Proto from an earlier purchase so I can only assume the tolerances are the same.
But the Italian (FACOM?) ratchet is soooo much more compact than the 24 tooth American version. It just seems better put together. The big USA ratchet is a lot wider but actually less tall than the Italian round head.
All this for less than $150? Awesome. This is why I thought we should consolidate the small liquidator sites into 1 thread.
2ndGearRubber
Pittsburgh
Got some stuff from rapid supplies, mostly for home use. Got a few things denied on the officecrave order last week, hopefully this order will have a better fill rate.
Gotta like cheap proto.
V
victor252
I know some people missed out on the Proto breaker bars from shown in the earlier threads. Looks like most of these sites still have the 18.5" in stock(5468 or PTO5468). Cleanitsupply is the most expensive before shipping but the rest are around $10 to $12.
https://www.rapidsupplies.com/proto-socket-hinge-handle-p/pto5468.htm
https://www.zerbee.com/Products/Soc...58in-Long__PTO5468.aspx?via=search&pq=PTO5468
http://www.alliancesupply.com/Produ...58in-Long__PTO5468.aspx?via=search&pq=PTO5468
The 24" PTO5469 is way more expensive where it's available. $47 before shipping. I think this is the one most people wanted.
http://www.alliancesupply.com/Products/12-Drive-24-Hinge-Handle__577-5469.aspx
V
victor252
How much and where did the 72 tooth Proto 15" ratchet come from?
I bought it a while ago from cleanitsupply but they're out. It cost me about $25. Now the cheapest place that has it is Zoro for $55 with free shipping. You might be able to use a 20% off coupon depending on if your order is large enough ($100 might be the minimum). Otherwise continue to watch the liquidators, ebay, etc.
https://www.zoro.com/proto-hand-rat...MIp_iQ843w3AIVGnZeCh3scQTWEAQYASABEgKVN_D_BwE
I like the ratchet a lot. Its swing arc is only 5 degrees compared to 15 for the coarse tooth models. The back drag is pretty light. Mine came lubed already but I wiped it down and added a fresh coating. Even then, it's about $10 cheaper than the newer model that has 45 teeth:
https://www.amazon.com/dp/B001VXYG2S/?tag=atomicindus08-20
V
victor252
Icecoldburr
Alabama
This was from my ReStockIt order. I know they were cheap tools, but the pry bar looks reminiscent of a garage sale find.
V
victor252
Just ordered a Proto mini sledge with free shipping. Really $12 and free shipping? But they use Amazon Pay so I assume they are legit.
Post here if you get your orders filled and I'll add Armor to the list of small liquidators.
Also :
locking welding vice grips for $5
https://amorsupply.com/irwin-vise-grip-locking-welding-clamp/
18" pope wrench for $9
https://amorsupply.com/irwin-vise-grip-cast-iron-pipe-wrench-274103/
1 1/4 striking wrench for $14
https://amorsupply.com/proto-heavy-duty-offset-striking-wrench-2620sw/
Apex/Armstrong brass hammer with free shipping $21
https://amorsupply.com/armstrong-tool-brass-hammer-69-515/
2ndGearRubber
Pittsburgh
Proto combos are anywhere between 4 and was 13 on there too. Including sizes like 1 1/4.
Use the search term PTO, that's the prefix for their proto stuff. Some is listed under Stanley black and decker, but cross checking the part numbers says proto.
mikebaker1129
Huffman,TX
Blackhawk 1/2" ratchet $7.99:
https://amorsupply.com/blackhawk-round-head-ratchet-socket-drive-49945b/
Proto 8" adjustable wrench $5.99:
https://amorsupply.com/proto-adjustable-wrench-pto708/
Proto 10" adjustable wrench $6.99:
https://amorsupply.com/proto-adjustable-wrench-pto710/
Proto hex key 18 piece set $9.99:
https://amorsupply.com/proto-hex-key-set-4986/
+$7.99 flat rate shipping
They do not have flat rate $7.99 shipping,unless it is per item. They wanted to charge me $115 shipping for $60 worth of stuff. They are only a few small towns over about 45 minute drive from me,so it is not like they are shipping the items across the country.
They have some good prices but apparently make up the difference in shipping,like some old school EBay sellers use to do.
KDoug
Southeast Texas
Did you try and call them, I can't see why they wouldn't adjust the shipping? I know it's different, but I have done that with Cripe Distributing off EBay when it shows I have to pay shipping for each item.
mikebaker1129
Huffman,TX
I emailed and the person responded that , that is how they make their money .
It is $7.99 flat rate shipping per item ,so a $2 Proto punch will cost you $9.
I have Called both Cripe and Abolox and had shipping charge adjustments.
I even asked about local pick up and was denied.
I am not dumping on these folks at all, just making everyone aware of what to expect.
I was just shocked at my $50 order, plus I pay TX sales tax and shipping = $185.
Jordanj
I've called twice with no answer to ask about a tracking number.
Its good to hear they respond by email.
I'll post up if I get my items.
I got free shipping, but had to pay TX tax. I'm in Katy,Tx
Jordanj
I don't know. I think they might have had different shipping options when I first ordered. I just put the same two items in the cart and flat rate was the only option. One $7.99 shipping charge for both items.
Jordanj
Your Order Contains...
Cart Items SKU Qty Item Price Item Total
10-Piece Hex-Bit Socket Set, Metric, 1/2" Drive, 6mm To 19mm
PTO5441MA 1 $38.99 USD $38.99 USD
7-Piece Hex-Bit Socket Set, Sae, 1/2"-Drive, 1/4" To 5/8"
PTO54417 1 $26.99 USD $26.99 USD
Subtotal: $65.98 USD
Shipping: $0.00 USD
Texas Tax : $5.45 USD
Grand Total: $71.43 USD
Payment Method: Credit Card
Amor Supply
potato
got this in an email from amorsupply.com....
Enter coupon code Savings during checkout to receive a $5.00 discount on shipping!
chickenfarmer
They've got some great deals on wire wheels to, I just placed an order and got shipping for $5 after the coupon code
Jordanj
Got a tracking number for my order today. I ordered another SAE set from Zerbee thinking this wouldn't get shipped. I'll sell it for what I paid if anyone wants it.
