circuit breakers
camaro77
rhode island
need to buy 7 square D circuit breakers where are you guys buying from the big box store (lowes & HD) must think they are gold plated. any good places to buy on lines
Thanks Jeff
ddawg16
S. California
I doubt they will be cheaper at an Electrical Contractor store.
Try Amazon....otherwise, 'embrace the gold'..............
Jlarson
I donno the orange and blue boxes really aren't too bad on plain jane QO and HOM breakers, I can't do much better then them at my supplier with discount but then again I don't put in a lot of square d.
tyme2par4
NH
From what I've seen Homeline breakers are about the same at amazon as all the local and big box stores.
slow
near Orlando
I get mine from the supply house (my dad's house) but what size and what do you think they should cost.
I had to buy some Federal Pacific compatible breakers for an old office years ago, $120 a piece for 40 amp 2 poles, I could have replaced the entire panel with SQ QO for the cost of the 5 breakers we had to purchase. (obviously, cost without labor)
NUTTSGT
Northern Central Ohio
Thanks Jeff
What size of breakers are you buying ? A simple single pole 15 or 20 amp breaker should be about $10. I don't think that is out of line, what are you expecting on paying ?
Jim greengo
Behind my house
Single poles are around $4-$5.00,2 poles are $8-$9.00 for home line anyway.
C
camaro77
rhode island
thanks guys I was not specific I was looking for 20 amp gfi breakers I got lucky and located 4 at lowes on close out for 55% off. the normal style breakers are cheap and the way the garage is ll wired up with dual boxes it was a cheaper option to do gfi breakers instead of the gfi plugs
NUTTSGT
You're right, I'm in the middle of looking up breakers (multitude of brands) for something and posting something totally different for other breakers. . . . brain and fingers on different paths.
NUTTSGT
GFCI breakers are more expensive but worth it when you consider the extra protection for your and loved ones.
Diesel Dan
TN
That's an understatement!
Must have over $600 in breakers.
Square D QO w/plug in neutral, 15&20A AFCI/GFCI combos are not cheap.
Box stores are, in my area, much cheaper than supply house.
Heck, they had to call the central office for the QO stuff since they don't deal with it much.
sberry
Brethren, Michigan
With some simple design planning could have bought 4 gfci outlets for 1 breaker. 28 of them for 7 and not had to consider replacement cost. I got 250, maybe 300 breakers, not 1 gfci. Have never used one on a new install I designed. Had to replace 1 recently for a neighbor with a modular built in 70's where that was a shortcut for spec designed wire at the time.
Diesel Dan
TN
At that cost, I would have gone with GFCI outlets also !
Don't forget AFCI too.
If you use afci/gfci receptacles the portion between the panel and receptacle is not protected. IIRC, code calls for the unprotected circuits to be in conduit.
Currently waiting on my $85 surge breaker, Model # QO250PSPD.
