camaro77
need to buy 7 square D circuit breakers where are you guys buying from the big box store (lowes & HD) must think they are gold plated. any good places to buy on lines
Thanks Jeff
Thanks Jeff
How much you think they are sposed to be?
Thanks Jeff
Single poles are around $4-$5.00,2 poles are $8-$9.00 for home line anyway.What size of breakers are you buying ? A simple single pole 15 or 20 amp breaker should be about $10. I don't think that is out of line, what are you expecting on paying ?
thanks guys I was not specific I was looking for 20 amp gfi breakers I got lucky and located 4 at lowes on close out for 55% off. the normal style breakers are cheap and the way the garage is ll wired up with dual boxes it was a cheaper option to do gfi breakers instead of the gfi plugs
That's an understatement!GFCI breakers are more expensive
With some simple design planning could have bought 4 gfci outlets for 1 breaker.
With some simple design planning could have bought 4 gfci outlets for 1 breaker. 28 of them for 7 and not had to consider replacement cost. I got 250, maybe 300 breakers, not 1 gfci. Have never used one on a new install I designed. Had to replace 1 recently for a neighbor with a modular built in 70's where that was a shortcut for spec designed wire at the time.
At that cost, I would have gone with GFCI outlets also !
