After reading for a while on here about using a torch to heat bolts that are rusty, I want to give it a try. I am trying to remove a seat bolt, which I believe is probably coated in blue thread locker. To date, I've broken two torx sockets trying to remove this stubborn bolt.
What I'm looking for is a kind that I can use a squeeze trigger to turn on and off. The ones I've seen on amazon lead me to feel that you ignite it and then move to the workplace. I don't really trust myself to not knock it into something, drop it, etc so I'm thinking something that auto ignited with a squeeze trigger would be best. When you release the trigger, it would cut out.
The smaller, the better. At some point, I'll have to use this to get to my manifold bolts on my F-150 if that helps.
I feel comfortable with using either propane or MAPP....or a universal?
