Been wanting a vise on the service truck for about 5 years now.... couldn’t see putting a high dollar one on it, so this 50 dollar c1 will work just fine. Decided not to use the swivel.
One pin, or bolt to pivot it three directions, no. Swivel bases do break. No swivel lock Dow’s to come loose.
All bolt on, all removable. Fully adjustable. “Jam” bolts welded on to ensure there is zero slop and 100% Ridgid. Harbor freight 12” receiver section drilled and tapped bolted into the existing frame/hutch assemble.
The a Combination of two adjustable hitch setups, 7” diameter 3/8 plate welded to one end of the adj hitch.
Waiting on some 5/8 Allen bolts to show up for safe security measures during normal use, then can remove it all together when I get into shadyville. Going to pick up a dry up pick jaws from nick this week since I’m in his stomping grounds.
Some bright obnoxious color to help people not run into it, either by leg or vehicle.
