Mr. Heater question.
swaterbenny
New Richmond, WI
I got my 80,000 btu heater fired up, and I feel like the flames are a little too yellow from other post I read on here, just looking for opinions. The last photo is from the first time I fired it up, yesterday. Thanks Ben
mm08822
Last photo probably the result of initial purging of air in fuel line.
Pic #2 looks fine.
What is your supply pressure while running?
bobbyjean
hudson valley n.y.
10.41 while running ...flame looks good..is it throwing a code or are you just concerend about flame? check your safeties to make sure they work and call it complete.
mm08822
10.41 is the manifold pressure. Question is about supply pressure.
swaterbenny
New Richmond, WI
I just read that there should be a strong blue flame with very little yellow, and that's what I'm questioning. I have a lot of blue, but the tip has a share of yellow to it. When I first started it for the first time it was mostly yellow, now after running for a while its settled down. Honestly I think it's good to go just looking for other opinions.
Here is a picture of the supply pressure at 11.40.
Thanks, Ben
mm08822
Not the same as being there and seeing it but flame in pic looks good.
I think you're done.
