I’m replacing an old oil steam boiler with a gas boiler. The oil boiler cracked (water spewing out the side) last winter after it was winterized by a boiler technician. Fortunately insurance is covering part of the damage.
I’ve gotten three quotes for the job : 9,000, 20,000, 25,000. All are inclusive of material and permits.
The property is a 3 family, 3 floors + basement and each floor is about 1100 sq ft.
I don’t know much about gas boilers …. and from what I’ve read this is not a DIY project at all, so i’m hiring pros.
All 3 quotes are for burnham boilers (independence). IN6 and the IN7. The btu range is - as low as 175K and as high as 210K.
How do I know whats right for the space and the existing steam system I have in place?
The 9K contractor (175K BTU) said installing a stainless steel chimney liner may not be necessary. They are going to clean the chimney I’ve read that dangerous gases can seep into the apartments if the chimney isn’t properly lined.
The 20K contractor hasn’t stated replacing the chimney liner. I’m inquiring further.
The 25K contractor is installing a chimney liner (6k included in 25k). He’s quoting the permit at 5K (included in quote).
Any advise on the process will be greatly appreciated.
I can include the line items of each quote if that helps.
