Sparkynutz
Cracks aren't even damp. There is a few coats of slightly flexible foundation coating on outside and outside was compacted pretty well. Not too worried just yet. This winter will be the real test if any heaves happen or if the ground dries out before freezing.
I put 1/4" fanfold insulation at top 16" that will act as my thermal break for slab. I didnt want to use a larger expansion joint material only at top because it will be seen, more to caulk, and more area for debris and **** too when sweeping. By keeping joint as small as possible once the slab is poured the outside wall won't be able to push in more than the 1/4" each side or whatever it compacts to. I don't plan on pinning slab to wall. It really shouldn't push out either unless massive amounts of water get in and it freezes. In that case I'm pretty sure the outside should still exert similar even pressure inward. I don't really see slab moving up or down much either as long as I do a good job compacting base. Hopefully that keeps slab from cracking except where I cut it.
Sent from my SM-G960U using Tapatalk
