Norseman Drill set deals
PT Doc
I have been able to put together a few group buys for Norseman drill products in years past. With these past promotions, all products from Norseman were offered at discounted prices. I have been contacted over the past months and see that there is some interest in folks wanting to buy Norseman Drill sets.
What I would like to know is what set numbers would you buy? Please provide the specific Norseman part number for the drill set you want. If there is a concensus on at least one set, then it might be possible to offer that set at a better discount.
Let me know what you guys want and I’ll do the work to get the best pricing. To make this happen, there needs to be quite a bit of interest.
Thanks
P
PT Doc
This is one that had a few requests.
Norseman, 93840, SP-115 Magnum Super Premium Drill Bit Set, Jobber Length, Black & Gold, 115pc
6PTsocket
There have been recent threads on this forum where people have been very unhappy with recent Norseman. Please don't take my word for it. Check it out.
B_Bimmer
Eastern Iowa
I have had good recent experiences, and would be interested in a comprehensive left hand set. The one I have skips too many sizes and when disaster strikes I want a full arsenal.
GRB
SoCal
I’ve spent over $1000 on Norseman drills in the last two years and have nothing but good to say about them. Curious about the negative experiences of others.
Drilling 2” thick steel with a 7/8” super magnum by hand with a D-handle Milwaukee earlier today.
Wamsutta
Amarillo, Texas
P
PT Doc
Re: Norseman Drill set dea
So I read that post I believe. I DO NOT want this post to be a carryover of that post. PLEASE!
Here is some information from my experience. I am not a machinist and do not drill hundreds of holes a day.
Sheet metal can be drilled with drills DESIGNED for that task or you can modify a drill bit for the task. If anyone is interested in modifying a drill then please check out Tom’s Techniques on You Tube where he modifies numerous drills for plastic, sheet metal and flat bottom drilling. He created the flat bottom drill video for me when I asked about this on a machinist forum. They are really good videos. Super knowledgeable machinist he is.
Chipped edges are likely caused by drilling freehand and not maintaining a stable drill orientation relative to the cutting surface. This will happen with any drill. A drill press can minimize or eliminate this if the material is well clamped. Stability is needed to get great looking holes. So either you use a handheld drill in a stable fashion or clamp the piece to the drill press table.
Small drills breaking is not uncommon. When flutes get packed then where can the chip go? It won’t go anywhere and the drill will break. Discolored tips indicate heat. With proper drilling and end mill use the heat should go into the chip. Using coolant or cutting oil is recommended for various reasons. Colored chips are great but colored drills are not.
Understanding proper speeds and feeds is key. You need to be cutting a chip. If you are not then you are rubbing and rubbing is not cutting. You can’t rub a hole into most things. Cardboard maybe. Bigger drills need slower speeds and smaller drills need higher speeds to maintain a reasonable surface feet per minute (sfpm). But you need to make some curlies. No chips, no good.
There are standard hss drill sets and there are cobalt sets. Picking the right drill material is helpful when drilling hard materials and getting great drill life. Split point drills at 135* will drill great in the correct material and will often times not need predrilling. A center punch mark often is sufficient to keep a drill on center.
Multiple failures in one set of drills is difficult to understand. They are produced by the manufacturer at different times. Heat treating is done in batches and no one drill set has all of those individual drills heat treated at the same time. So it can’t be a heat treat failure. Quality control at modern production facilities is really over the top. But this ensures that poor quality products to not make it out the doors.
So I’m not sure what happened but reading up on Norseman online on multiple forums will give a great birds eye view of many people’s experiences. Norseman produces drills for industrial users. You cannot produce **** and get away with it. You just can’t.
I have many many Norseman drills various lengths, materials and sizes. I have not had any problems unless I caused them by doing some or all of the above listed practices. ;) It’s pretty simple in my opinion. Everyone needs to learn to drill on a drill press and understand some basic concepts. In the process we might make some mistakes but in the end anyone can drill great holes. On a drill press or freehand. Give a machinist some cheap chinese drills and they can make the best out of that situation and drill some good holes. But that person would take into account that lack of quality of the drills, not overfeed or underfeed, use proper speeds and know when to touch up the cutting edges.
Now back to our scheduled programming..... :)
P
PT Doc
P
PT Doc
You clearly know what you are doing.
winlinmac
USA
Buy Norseman off eBay via authorized sellers, never had problem. Replacement bits sold separately as well
P
PT Doc
Great point about authorized dealers. To maintain warranty a manufacturer could require purchase from an authorized dealer.
These drill bits would be provided by Industrial Supply Center in NC and they ahave been an authorized dealer for many years.
Iscsupplies.com
P
PT Doc
I would be interested in the step drill bits.
x3 plus step bits.:thumbup:
For those that want a step drill set, this set seems like a good one.
#68581 Titanium Nitride coated 3 piece set, quick release, impact ready.
Range. Shank size. Step increments. Step thicknesss.
1/8” - 1/2”: 1/4” 1/32” 1/8”
3/16 - 7/8”: 3/8” 1/16” 1/8”
7/8” - 1 1/8”: 3/8” 27/64” 9/64”
What do you think?
GRB
SoCal
I have the 01981 4 Piece Step Drill set and have been as impressed with that as the other Norseman bits.
I do think all the quick release bits are 1/4" standard impact socket drive. I haven't tried quick release step drill bits but for their intended use, they make a lot of sense.
I see in my attempt to minimize the criticism of Norseman bits, I might have continued it. Instead of saying I was "curious" about the criticism, I should have said I was "skeptical". PT Doc's post above about how drill bits are manufactured and used is exactly why I was skeptical.
Buckgnarly
VT
What do you think?
Looks good to me, I could use the smaller steps in that set.
P
PT Doc
Re: Norseman Drill set deal
87853; LF-17 is of interest.
I had been looking at the various left hand drill sets and was having a difficult time figuring out what would be useful. Initially a set up to 1/2” made sense. A set with just small bits doesn’t seem to make sense. Then I priced a 29 piece set just out of curiosity and holy cow. I knew it would be expensive but $380.
Set #87853:
1/16 - 1/4” by 64ths, 5/16 to 1/2” by 16ths.
Price wise this set seems to be the best value and the most reasonable range. Hopefully it comes in a Huot Index. So far all my Norseman sets have come in huot indexes which really are super nice.
P
PT Doc
For this that are looking to get a larger set of drills, would you prefer jobber length or screw machine length?
For drilling thick material jobber length seems logical. For maximal rigidity, screw machine makes a whole lot of sense.
Tallpilot
Orlando
If I am reading the catalog correctly the jobber length have 3 flats on the shank and the machine screw length do not. I would prefer the jobber length in that case.
P
PT Doc
Good point on the 3 flats. There are some drills that have 3 flats. These might be called mechanics drills. I have many Norseman drills and none have flats so that is a specialty configuration.
I will measure a few of my screw machine and jobber lengths in same sizes and reports back so that you guys can have a sense of overall length and flute length.
P
PT Doc
Here some quick measurements of my cobalt jobber length drills and my super magnum (SM) screw machine drills. Mechanics length drillmdimensionsmwere taken directly from the Norseman online catalog.
1/2” drill
Cobalt jobber 6.070 OAL / 4.618 flute length
SM screw 3.884 / 2.430
Mechnics 5” / 3.375
11/32” drill
Cobalt jobber 4.776 / 3.564
SM screw 3.086 / 1.792
Mechanics 4.125 / 2.625
5/32 drill
Cobalt jobber 3.152 / 2.029
SM screw 2.133 / 1.079
Mechanics 2.75 / 1.6875
Hope these dimensions help you decide what would work out best for you guys.
amolaver
Depending on what the discount ends up being, I could be in for both the lf-17 and the screw machine spt-29.
ahm
GRB
SoCal
Norseman is superior company to Drill Hog so no, you don't need to beat the price.
Jobber length is the normal length of drill bit. Mechanics length is about 20% shorter and were designed for hand drilling. Shorter makes them harder to break and the three flats work better with the poorer quality chucks common in portable drills. You will have to work hard to break Mechanic's Length Super Premium bits.
Norseman does have a new series of drills with a different hardening process that are jobber length and have three flats. I have not tried them.
Norseman and Triumph and many others have charts on their web pages explaining about the advantages of different tip angles and different materials. Read it and you will probably be buying far less Cobalt Drill bits for most uses. You will also start to understand why the Norseman Super Premium bits work so well in steel and stainless steel assuming you know how to get the speeds and feeds right. See PT Doc's excellent post above about making chips while you cut. If you are spinning too fast or not applying enough force, then Cobalt is more heat resistant and harder to ruin by improper use.
