What’s everyone’s favourite tool
Elvie84
BrisVegas/Australia
Mine would have to be the Sidchrome 1/2 Socket set that I got cheap from a carboot market stall,and a few of my snap on spanners.
Tynee
In the Heart of the Bluegrass
I’ve said in other threads that if anything ever happens to my Channellock 422’s, I’ll have to give up auto maintenance and home repairs. I’ll just turn in the rest of my tools.
tanukiboy
Japan
They may not be the most often used tool in my toolbox (but they are used surprisingly often): I'd say my Tsunoda cable tie nippers. They are great not only for cutting cable ties, but also wires because it holds the cut strands and keeps them from falling or flying off and causing a short circuit somewhere. How did I ever live without these?!
View media item 85526
View media item 87455
PT Doc
Knipex plier wrench. For sure. Everyone should have one. I need a few more.
marineman
Wild Rose, WI
Not the most glorious tool but my snapon PWCS7ACF wire stripper/ crimper saves me more headaches than any other tool in my box. Before I started working on trucks for a living I thought I was good with the strippers and crimpers I had but doing tidy work inside a dash or in a nook or cranny on the truck being able to crimp with the tip of the pliers is a god send. Maybe somebody else makes one that crimps at the front I didn't really look I just bought it when snapon guy came.
FullRaceMerc
SoCal (SGV)
The Proto "breakaway" torque wrench that my boss gave me for Christmas when I worked in a hardware store 40 years ago. Good man, good place to work, good customers, good tool. I think back to all of them when I use it.
S/RConcepts
Illinois
Here in the rust belt... Knipex Cobras. Worth twice their weight in gold around here, works like pure magic on all of the rusty fasteners you can imagine. I'll be the first to admit I was extremely skeptical when I first tried a pair, but I'll never be without them again.
MushCreek
Upstate South Carolina
Stationary power tool- Bridgeport mill
Stationary power tool- woodworking- Ridgid table saw
Portable power tool- corded- Bosch jigsaw
Portable power tool- cordless- Milwaukee 1/2"impact
Favorite hand tool- (hard to pick a favorite)- Lixie 168 oz. dead-blow hammer
Close second- GearWrench ratchets- so smoooooth.
Fialaja
Reciprocating saw A.K.A Sawzall. doesn’t matter which one of the five that I own but there’s nothing like tearing up something.
My Milwaukee’s are usually the go to, but the makita 3070 is just as capable, just a bit heavier, while the Dewalt is for when I need a cordless, thankfully not very often and mostly pruning/branch removal as it is the least pleasurable tool to use ( I hate the lever blade change and the lack of counterbalance, orbital action or general feel of the tool.) but it too has held up to extreme use... then there’s the little Ridgid fuego that is more akin to a scalpel than a sledgehammer. Definitely a tool worth having for those cuts where a full size saw doesn’t fit or you can only use one hand to make the cut.
At one point I was thinking of restoring old USA made Milwaukee sawzalls off eBay as a hobby, as the parts are still readily available. Sure would be cheaper than restoring cars! (And easier too)
Fedwrench
Valley of the sun
Easily my Alexander brand pocket screwdriver:thumbup:
It's a mini pry bar, opens parts boxes, helps with connectors, and has a strong magnet that that sticks to most drivers door window frames as i enter & exit a vehicle.
Next to a really bright Coast or Streamlight pocket LED flashlight, it's the tool i use most. :beer:
ChrisLS8
Probably my 3/8 M12 stubby. I literally tore the front end of my Nissan off to replace the radiator support in about an hour with my Astro stubby sockets. I've had air stubbies but this is a game changer.
cliftonbros89
Missouri
My Martin 12 point flare nut wrenches, Martin/Snap On 12 point flare nut crowfoot wrenches, Martin service wrenches for hydraulic work.
ssdave
Eastern Oregon
My little red box with a Snap-on midget, set of extensions, and SAE and Metric sockets. Getting that quality 1/4" set made an immense difference in how I use tools, I found that the quality set let me do the work of a 3/8" set with 1/4" drive. More agile, lighter weight, fits into tighter places. It also led me to eliminate cheap tools from my stuff, and only use good ones, once I realized that there really is a difference and it is sustantial in some cases.
matthew
Possibly my Wera bit ratchet. It has replaced an inexpensive bit ratchet that is also awesome, just not quite as nice.
It is amazing how often a bit ratchet is necessary because you can't fit a normal screwdriver.
Wamsutta
Amarillo, Texas
3/8'' drive 7.25 inches overall length.
samss
Conway, AR
M12 1/4" hex driver. Too many years of nut drivers and screw drivers have done a number on my wrists.
