30x50 garage with lifts
scoobydoo666
Canada
Hello there. I have been following many garage projects here and they have given me many ideas for mine. I started the project 2 months ago.
The plan was: radiant concrete , 2 post lift, in ground scissor lift. 12,5 foot of ceiling.
Trench for electricity and both hot/cold water.
Floor drain and drain for bottom of scissor lifts (I ended up switching location for these)
Hydrofoam for radian pipes
bc35ccb4459efefb1940b77237763392.jpglift boxes with drains
We poured in Friday in lifted the wall on Saturday. Motivating.
0abc770bf41b50ec013c2aefbb0db4cc.jpg022c30cc6a7792b5501101dfaba33478.jpgf8d59b161f1b1398e22caf5adfbd347e.jpg1ca5fa0980ef3715624fe46c0c193e34.jpg
Preparing the trusts for next weekend today.
More later!!
Envoyé de mon iPhone en utilisant Tapatalk
CombatNinja
I am confused as to why there are no footers. That appears to be a floating slab. In Canada!?
jayoldschool
Canada
Pretty sure that a slab that size needs footers in Canada. I seem to remember them clearly on the plans when I was looking at garage builds through Home Hardware Building Centre.
850xpeps
Yes. It’s pretty common for garages. Not for homes.
Floating slabs are common in both but it should be thickened edge not a straight 6” and a curb does not qualify as a thickened edge.
Sent from my iPad using Tapatalk Pro
scoobydoo666
Canada
It was thickened all around.
Hard to see from the angle but it has a drop of 6 inches all around with rods I added after this picture. So 6 inch edge, 5,5 slab and 6 inch wall.
scoobydoo666
Canada
Also note that it misses foam in the pic. Finished product was all foamed and with eurethane spray foam in cracks and gaps.
We frames some more today and finished the walls.
Ready for roof next weekend.
850xpeps
So it’s sloped to 11” thick?
It looks to be an even slope. It should be at least 16” thick imo on the edge flat on the bottom for the same width then slope up at a 45. That’s not the way to create a thickened edge if that’s how it’s made and appears to be from the photo.
And what’s with the mesh? I hope you added rebar at 12-16” center a each direction before you poured?
Ret Nailbender
Southern Oregon
You must work in construction. Very impressive to raise 2x6 walls, 50' long, and 12' 6" high with what appears to be a crew of four. How thick is the Isoclad and does it have any sheer value? Great looking build.
scoobydoo666
Canada
Yes I added rebar all around the perimeter.
scoobydoo666
Canada
I don’t work in construction.. I hire guys that do then work with them. For the 50 feet walls we did two 25.
All the walls were up in 8 hrs.
scoobydoo666
Canada
More work done this week end.
b7349994f3a3ae71b5285aa41a382ff5.jpg16586ac0962ca32aeeecef40f17258c4.jpgc9c7bc5bc5be4731741eaaef4dbb67d3.jpgc54451a3eb59c2dca7b3450f46d37a8f.jpg
Isulation done. Ready for steel roofing and electricity inside.
scoobydoo666
Canada
Ready for electricity!
scoobydoo666
Canada
Looks great, I'm considering the same size for my property. I'm anxious to see a couple vehicles inside.
I had plans for 30x60 originally but went down to 50. It is still pretty huge I find. It’s going to look smaller when the 24x16 spraybooth is installed inside.
scoobydoo666
Canada
590bcd27a134f79b4d0ecfe009272fb1.jpgb6a9c991e196376016e948309028abd3.jpga02317cc58de28b2d599638a0c699044.jpg
Wiring day
Deezler
Southeast MI
Dang, thats a big panel. It looks like you might have mounted your radiant boiler setup a bit high.... pex don't reach! lol. Is that a blue ridge pre-fab'd setup?
scoobydoo666
Canada
The panel was mounted by a local business.
I will extend the lines of course. Did not want to knock my head on the components. My 2 post will be right next to it.
scoobydoo666
Canada
Steel roof going on
Ready for steel inside
scoobydoo666
Canada
More work done!!
scoobydoo666
Canada
Old one:
New beast!!:
scoobydoo666
Canada
Getting there!! Will need paint. And neons.
FANTM58
Brighton, Co
Are your radiant lopos on 12” centers ?
That seems a bit too far ?
Was that designed that way .
Mine were on 6” is why I’m asking.
scoobydoo666
Canada
Yes 12 inch. That’s how everyone does it around here at least..
scoobydoo666
Canada
scoobydoo666
Canada
Doors!!
tapout187
New Jersey
Very nice garage!! I like the steel on the inside, is that the same as used on pole building exterior siding? Where did you get that from? Awesome what you’ve accomplished so far!!
scoobydoo666
Canada
Thanks and thanks!!
The inside steel is called Victoria. It’s a bit cheaper than the Vicwest on the roof. Made for walls so very thin.
