Need help: Genysis Scanner Battery
lynam
CANADA
We bought our (shop) genysis scanner used and it wont even turn on because the battery is no good. Would be nice to know. I know there was a 1-800 number on the battery.
R
regguy1
On Mount Olympus with Zeus
I see them online for 70-90.00. someone on ebay selling a used scanner that needs battery claims you can buy one at batterys plus for 32.00....?
Maybe someone here knows more.
R
regguy1
You might be able to use it if you keep the charger plugged in while doing the scan..it worked for me yesterday
Kevin7909
Guys:
That pack is the same thing used in 9.6V RC cars. You can purchase 9.6V NiMH battery packs that size for much less than $35. Look around. If you want one that has a *lot* of power (2500mAH) then go to maxamps.com, get the phone number and call and get the correct connector for your unit. I use the 2500mAH and it is a good battery and less than $30.
Here is one with less mAH for $12.99:
http://www.batteryjunction.com/y2et-wmh9-6aa2000-z.html
Kevin
lynam
CANADA
We did wire it up to a converter and it works. The battery is the weak point. For daily use right now its useless!
