Show your new tool arrivals
MattVette89
SW Chicago
I made two frivolous purchases this week. A Milwaukee M18 fuel 3/8" impact (210 ft lbs) and a Snap-on SAE nut driver set. Got a deal on both so I don't feel too bad. :lol_hitti
Ign
Butte Peak ND
AP Goliath BJ press. Woot woot
And Metabo 4.5" flat head angle grinder. I was never able to swallow the $230-240 retail on these, but this was AWD at $175. Still spendy for a grinder but realizing it's a special use/special situation tool I'm happy.
48548
Phoenix
I would pick one up for that price as well...
looking for a pebble 4766 or any 47xx pebble hinged handle
Mike.ASC
East coast
Jazz1
Thunder Bay On.
#1 son bought this GE thickness planer for $100. 220 Volt. Runs perfect and came with extra knives. Its old and heavy. Needed my cherry picker to get it off the truck.
rshadd
Doylestown, PA
Bosch CCSCL Large Case for Custom Case System (Case Only)
Bosch CCSPHV208 8-Piece Impact Tough Phillips 2 In. Power Bits with Clip for Custom Case System
Bosch CCSSQV208 8-Piece Impact Tough Square 2 In. Power Bits with Clip for Custom Case System
Bosch CCSTV208 8-Piece Impact Tough Torx 2 In. Power Bits with Clip for Custom Case System
Bosch ITNS122 Impact Tough 2-9/16 In. x 1/2 In. Nutsetter
Bosch CCSNSV17804 4-Piece 1-7/8 In. Nutsetters with Clip for Custom Case System
BOSCH 16” X 12” X 4” Large Contractors Tool Bag Tote Case w/ Inside Pocket
okie18
Be aware those super low cost units are 3ph only and the phasing can not be altered.
Yep. As cheap as they are you can almost buy a phase converter and still be in it less than a single phase unit.
Sent from my SAMSUNG-SM-G890A using Tapatalk
sweet victory
USA
Got a new case for my most used tool...my PC. Previous case was a little too small for use with the CPU cooler, so got a mid tower.
During the case swap.
DSC01325 by P A, on Flickr
I'm "meh" at cable management. Good enough for the girls I go out with?
DSC01326 by P A, on Flickr
Everything swapped over and buttoned up. Made this post with everything all hooked up again. Nothing is on fire...yet
DSC01328 by P A, on Flickr
Distrophe
Just got my MilW 2727 chainsaw. So here's a Pic for LuLz.ff866fea0bb626efa38a386a7ef9407d.jpg767b2b480e1133beedf12f8955344c47.jpg
losvre
UK
Very neat, that is how it should be[emoji106]
Sent from my SM-A510F using Tapatalk
protegeV
DFW
I had to look up the purpose of that tool: A valve stem remover.
more of a valve stem installer. I mean it does both, but I've been know to rip them out with a regular pair of pliers. It requires a lighter touch to install them though :bounce:
L.Cheapo
More of an installer. It appears to actually be a Lang 1410 with a Snap-on hard handle on it. But the price was nearly the same and I could have the Snap-on TODAY and not in 9-12 days like the Lang. The new version has an Instinct handle, and I'm not fond of those. My dealer had this one "forever".
PelicanPines
Something most people will never do unless you work in a shop or have your own tire machine at home.
Do not work in a shop or have a tire machine.
The vast majority of the times that I have used the valve core tools, have been on split-rim wheels with tubes.
I use a stem tool on lawn tractor tires...
dodge610
North Canton Ohio
97b98a3ace92b85581694aa0acbacd6e.jpg54db61fea48ae8221966a1a4695909bd.jpg Just a few things from Sears while I can still get them.
Gears_call
California
I picked up a krsc46 in extreme green with black trim today :thumbup:
sweet victory
USA
I forgot to mention. I trimmed the mat that came with my box to fit the stainless top. (For use when you don't have a work top) Way less glare! Absolutely love this work top now. Used a straight edge and Ofla razor, and it looks OEM. Trimmed it to sit along the inner bend radius of the work top. :)
DSC01313 by P A, on Flickr
Decided to go ahead and upgrade a bunch of my 3/8" drive stuff since my dealer had the BOGO free promo running. Will have a ton of Gearwrench sockets for sale soon....
DSC01332 by P A, on Flickr
DSC01335 by P A, on Flickr
DSC01337 by P A, on Flickr
DSC01340 by P A, on Flickr
WWheeler
Middleofnowhere USA
Nice box. Boy have you ever been filling it up.
Is the hutch pegboard pattern and accessories that fit it exclusive to snap-on?
chrisnazzy
Arizona
New hard handled 7 pc. Torx screwdriver set. SDDTX70AO.b159957eb8f59505a406bbaa2c0eea1e.jpg
cstmg8
Pickerington, oh
Nothing exciting, just adding some ratchets to the work tool box:
Also received my eBay brake tools, but haven't opened them yet.
sweet victory
USA
Got a long way to go! Since I'm using VIM mag rails..it's hilarious how empty that top drawer looks. I could probably fit every socket Snap On makes from 1/4" to 3/4" drive using the magrails. Since I've only been needing metric stuff...that top drawer is ~15% full? If that...
The pattern is called slot & dot. Snap On makes a variety of accessories, but thanks to the "dots", it's universal. You get a packet of screws that screw into the "dots." You also get a ton of various clips; that's how you see people hanging their ratchets. As long as whatever you're trying to hang has a hole, you can secure it to the board using the screws. I've seen TV's hung, Wera screwdriver racks, pneumatic ratchet holders, etc.
lugnut71
Wyoming
I like the stainless top but really prefer the rubber mat, I did the same thing when I had my 68 epiq with the hutch, the glare was really messing with my eyes. I also didn't like the glare on the front strip of stainless, so I cut a second mat 1/2" larger for the recess, then cut a 3rd mat tight against the hutch and it came out flush with the stainless top.
sweet victory
USA
Been thinking about making a diffuser for the light bar. That would take away the harshness.
lugnut71
Wyoming
I would like to see that diffuser, I honestly don't know how full time mechanics deal with the glare off the stainless top all day, it blinds me then you turn around to what your working on and its soo dark, like walking inside after shoveling snow.
Carquest
South Carolina
Also purchased a Torch300, still waiting on my Underhood light and flush cut pliers to arrive.
