Waste oil heaters
mounds1730
I have an MX 150 Lanair waste oil furnace. I use this furnace to heat my 30 x 50 shop. I do all repair work to the heater myself. My location si Southern IL.
Charles (in GA)
50 mi south of Atlanta
OK, pics of your installation and shop plz. You cannot just jump on here and tell us something without showing us............. :lol_hitti
We are a bunch of visual people....................
Here is my MX200 installation thread.
http://www.garagejournal.com/forum/showthread.php?t=86184
Charles
Charles (in GA)
Welcome to GJ, its a great place...
Also, OP needs to go to User CP (control panel) in the menu bar across the top of the GJ page, and edit his profile to include a location (So. Illinois is sufficient) as it helps in the future when you ask a question that may be weather or code related.
Charles
Shop Specialties
Grass Range, MT
2 Clean Burn CB 5000 and 1 CB 3250 with custom made 1,100 gallon tanks with stand for one of my customers. Also check out the correct way to install stovepipe.
Shop Specialties
Grass Range, MT
Gallons per square foot ? I have never been asked that question yet.
I am assuming you are asking gallons per year ? I have customers burning anywhere from 200 - 15,000 gallons per year.
Heavymetalmechanic
Calgary, Alberta, Canada
I guess it's a stupid question, too many variables (location, shop size/hight, insulation etc.) to take into account.
I just got curious after seeing the different sizes of oil storage being used.
Charles (in GA)
You size the heater to the building like you would any heater. The heater BTU will determine how much fuel in Gal/hr you are going to burn (running continuous). mine is rated at 1.44 gal per hr and it is 200K btu. with it cycling on and off, it probably averages close to 1 gal per hour actual consumption. Of course this depends on outside air temp/heat loss, etc that determines how much the heater cycles.
It all depends on whether you run it 24/7 or have a climate with wild temp swings and possibly you only use the building part of the time and don't have an issue with the building getting cold when you are not using it.
In any case, its a lot of oil and you will need lots of friends or good sources of oil. I was just given a gallon by one co-worker today, another gave me about 3 gals. I collect it all year.
Charles
Shop Specialties
Grass Range, MT
CB 1750 with a 250 gallon UL spec tank/stand.50a07d5d77811825a11d5df9c9f0bfde.jpg7711e6215b9651dca4d165e486db9e81.jpg
Sent from my XT1028 using Tapatalk
Milton Shaw
I usually find the oil is hot enough when I drain it that I don't need a waste oil heater. LOL. It's just about like call some thing a Hot Water Heater instead of a water heater.
Low50s
NE Iowa
Bumping this thread, Man I want something like this in my garage. I could definitely get away with something smaller in size but I keep coming back to I want a Clean Burn heater !! I just cant find a good used unit !
Shop Specialties
Grass Range, MT
To bad you did not live closer otherwise I could help you out.
Low50s
NE Iowa
I have tried to contact my local dealer master burn by email two times with no reply, I try using email for 2 reasons, I can try and make contact at the end of the day when I can actually take a seat and 2 then I have records. But every time I contact them I don’t get reply’s
Shop Specialties
Grass Range, MT
Shoot me an email to [email protected] with your info. I will try to get a hold of them for you and see if that will help.
