booch
Great shots from the bridge; the effect of the spotlights going through the clouds is something I never saw in my years living in Williamsburg.
Just finished all 137 pages over the past 3 nights. Thanks for taking us along. EPIC story, awesome rabbit holes and guess what I'm having for breakfast after this night shift............m-f'n pancakes!
Love the MCM style and congrats on rescuing and restoring your home! I respect your skills and and your tenacity!
Thanks for 'liking' my Staintune post on IG! Had Staintunes on my '02 VFR that I'm sending down the road and it sounded amazing. Had to get the same pipe for the minty '95 I picked up.
Looking forward to what you have in store for us next![]()
...Friends have walked into the shop to the sound of Verdi and he smell of carb cleaner. There is a kind of zen there...
A new way to make a campfire called the "upside down fire" and since i fancy myself as a capable fire maker I was a bit surprised to not know this method. It's basically what it says - big stuff on the bottom, tightly packed and smaller as you go up. You light it and the coals fall down to the larger wood and it feeds itself and can burn for hours with no tending.
Of course I like tending a fire so I felt a bit deprived.
Gregor
Gregor
To get all the built up carbon off there's two methods. The first is to spray it with oven cleaner and place it in a plastic bag for a few days. Oven cleaner is basically lye so the second method cuts to the chase - a lye bath.
Gregor
Yet another addition to your list of skills, Gregor. Next you'll be telling us you've entered the Baja Rally....
Matthew.
Glad that this remains entertaining even when off topic.
So I had prepared some images of another small project but was feeling like it was another rabbit hole that maybe didn't warrant jumping in - then my sister sent me a text showing me some cool old cast iron cookware that was my fathers and she wanted to know how to restore it.
So here we go.
My kids love junk shops and so do I. For them it's the crazy variety of things and for me it's the chance to find some old tool, fan, axe or whatnot. Or a nice cast iron pan. Cast iron as you most likely know is the original non-stick cookware. I've owned a lot of it over the years and like my fans I have come to appreciate a certain genre - older Griswold with the large logo is my jam. Old cast iron is very high quality, much lighter and typically much smoother as they took the time to finish them.
On our way back from camping we stopped in a shop and I found a nice #6 Griswold pan for $15. Deals are still out there. I have a #8 and for that money I figured it would be fun to fix up. So here's my process - pay attention Lara!
Things to look for on old cast iron is warping and cracking which is pretty rare. If it doesn't wobble too much on a flat surface and you see no obvious cracks you're probably good to go. Check ebay for a sense of what they're going for. And for Griswolds here's a good link or this one. This pan was really well used but it was the larger cross logo that I like and I hoped it would clean up well.
To get all the built up carbon off there's two methods. The first is to spray it with oven cleaner and place it in a plastic bag for a few days. Oven cleaner is basically lye so the second method cuts to the chase - a lye bath. Drain cleaner is typically lye or if you bake German style pretzels you might have some pure food grade lye which is the best option. I use a couple of tablespoons per gallon and always add the lye to the water. If it's rusted you can do a vinegar bath, coke bath or my favorite is phosphoric acid but unlike the lye don't leave it unattended or it will eat the cast iron. Lye is harmless to the metal but not skin or eyes - wear glasses and gloves and rinse it each time it comes out of the lye.
First dip of a few hours and the handle is pretty clean.
Second dip is a few more hours and then a few minutes of scrubbing with a retired wire brush.
My trusty 5 in 1 tool goes to work scraping the heavy deposits. Often the sides aren't cleaned as well as the inside so they have the heaviest deposits.
Getting closer.
Inside is very good now save for a few stubborn spots so I go to the bead blaster to get the last bits and the lettering.
Next step is to just wash it out with some soap and water.
There's a million opinions about how to season cast iron but don't get caught up on which is best.
The whole point of cast iron is that it thrives on abuse and gets better with use. Add a little bit of vegetable oil (any kind) to the pan and wipe it all over inside and out until it's coated and then take off all that you can. The less on there the better. Put it in your oven at 450-500 and leave it for an hour. That's enough to get you started as the oil will cross-link and polymerize creating the non-stick surface you're after. You can keep wiping it down every 30 minutes with super light coats and keep putting it back but now the best thing you can do is to start using it.
It's not fully black again yet - that will take a while longer - but it's pretty close and already working well. Cooking bacon is great as there's a lot of good fats there - same with brats. Anything that goes with beer really because you deserve one. Wipe it clean and don't worry about it. Unlike non-stick cookware it gets better with use not worse. You can use soap - it won't destroy the surface but if it gets really messy just let it soak in hot water for a bit then scrub it clean.
So, Lara, that's how you clean up Dad's cast iron dutch oven. Good luck and I'll send you a good bread recipe when you're ready.
Gregor
So its ok to leave the cast iron in the lye solution for 24 hrs? I have had a few pieces of cast iron for a few years that I have needed to work on. Your post here finally has gotten me to get off my but and start working on getting them up to snuff.
Thank you for this thread and thank you for spurring me to get this project done.
I'm not sure that the electrolysis will work for removing baked on nastiness. It's great for rust, but there's no positive/negative attraction for old food and grease.
If there are 3-4 that need to be taken to bare metal I use the self-cleaning mode of the oven. Singles go in the lye bath.
I too have an affinity for the Griswolds, but have several makes in my small collection, all of which see regular use.
...I have a little bit of a motorcycle project...
Not sure if this will solve your shimmy problem but here it is for what its worth...
Many people should have that printed on T-shirts, but you & I should have that tattooed.
I used to have Leonard build up the axles when I was building Jeeps. He was always kind of a gruff guy until you get to know him but was the best around. Glad to see he is still keeping busy.
nate
Gregor, it's why we follow you so closely.It's nice to meet people who are really great at what they do and smart about how they do it.
Gregor
It's funny because everyone told me that as a warning. I think he just doesn't suffer fools. Once he saw that I understood what was going on and that I was being systematic and thoughtful he was super nice. Gave me lots of time and didn't want any money - just thought the problem was interesting.
Gregor
The death wobble story is a cautionary tale for anyone building anything mechanical. Many moving parts and many stationary (yet possibly flexy) parts offer a shitload of potential problems. The project being a vehicle in which your family rides most certainly amplifies the intensity.
I can only imagine the frustration and degrees of scared/pissed that the DW triggered... but I was still surprised at the scorched earth option taken on Expedition Portal.
Anywho.. Good luck with the projects. I am still enjoying your dedication to every craft.
