Need some tape for the engine bay
larryq
I had to install some new rear brake lines on my car, and previously when they threaded up and into the engine bay they were connected with a rubber triangle/grommet against the firewall so as not to rub against the steel.
They were taped into place in the grommet, and I need to re-tape. The prior tape was a kind of mixture of electrical on the outside and cloth on the inside; any recommendations on what to use here?
garagelogician
Blaine, MN
theoldwizard1
SE MI
If it is going to rub, it is going to wear. Only a matter of how fast !
I had some A/C lines that were clamped to a frame rail. I cut a piece of heater hose, slit it and placed it over the A/C line. That will take a LONG time to wear through !
Squankum
Southeast
