Need help finding a capacitor for old Airco welder
1233user
CT
One of the capacitors in my old Airco Dip-Pak 200 welder is bad and I am not having any luck finding a replacement. The capacitor is made by Mallory, its 2" od, 4 3/8" total height, and 7/8" spacing for the screw terminals. Its 10000mfd, 50v DC, and the numbers on it are 1373-2230 and 235-8408H. I have tried all the online capacitor cross reference charts I can find, but nothing at all comes up on any of them. I believe this welder was made in the 70's. Any ideas on finding a good cross reference for this? Thanks!
dogdog
Plenty of those in the surplus market...
You needed to match capacitance.. max voltage and surge voltage (sometimes not listed on the cap) if any, and temp ratings...
These are DC caps... so no frequency... you can use higher voltage or higher capacitance if you find one for cheaper...
The temp rating type CGR might be hard to find... if anything you can parallel two together as long as the voltage meet or exceed that 50VDC...
Some of the other brand I have seen other than mallory are
Kemet
Sprague
and something else I don't remember, have to dig in my box...
for example here is a listing just searching..
https://www.ebay.com/p/2-Phlips-150...186GG153T150AMA1/16010513652?iid=352433239908
you can google for "type CGR capcacitor" or "Welder Capacitor" maybe ? as long as the parameter meet or exceed your current rating...
toplessHO
central florida
might try Skycraft in Winter Park Fl
what ever you do,have someone bring this up slow and easy
old caps get very fussy and must never be put to full use right away or BANG.
1233user
CT
Google "CGR103U050V4C ".
There are cheaper ones with the same stats but not made by Mallory that should work. There is also this: https://www.ebay.com/itm/302788218971
The 2 above look like an almost exact replacement. Can I ask how you guys found that other part number? I went through every capacitor cross reference site I could find, and none of them came up with any cross for the numbers on my original capacitor. Thanks everyone for all the help!
kaffine
Henderson, NV
Another possible option https://www.digikey.com/product-detail/en/united-chemi-con/E36D101LPN103TC92M/565-3299-ND/2095913
To find them go to one of the major electronic component websites and go to components capacitors and use their search filters to narrow down the results to what you are looking for. I switch between which supplier I use as the search filters are different between them so I will use the one that has the options I am worried about.
www.digikey.com
www.mouser.com
www.jameco.com
www.newark.com
The 52 Ford
Virginia
I was going to make the same suggestions that Kaffine made. I suppose you could also check to see if there is anybody local selling electronic parts and give them a call. Either in a phone book (if they still make those) or just check your search engine.
American Locomotive
Rhode Island
Sometimes just typing what you have into Google will provide good results. For example, just searching for "Mallory 10000 uf 50v" on e-bay pops up with a lot of results.
byoungblood
Berryville, VA
