let's see your craftsman block grinders
bubinga
WWShop
MN
Rabid Badger;7524367 I was going to use the usual gray but the wife saw the red and insisted.[/QUOTE said:
Ohhhh?? So it was actually your wife who did the restoration and you're just taking credit for her amazing work!! Just kidding! :)
drivesitfar
WW: I rarely use the eye shields and this old craftsman pre block grinder has been sitting on a shelf waiting for me to find a spot for it. so I guess the answer is no i haven't tried to find any.
Rapid: your bride has good taste in men and colors cause you've got skills. :thumbup:
beltdrive
Smithfield, RI
So I picked up a 1/2 horse 1959 craftsman block grinder last night...drove an hour in the rain to Narragansett RI....THING IS BEAUTIFUL CONDITION ON THE STAND....industrial rated with lamp and eye shields. Question....it has a 220 plug on it. Is there anything I have to do to make it run 110? I keep buying these and trading up...the late 50s are freaking awesome.
PS grinder shows both voltages on the label and says dual voltage.
beltdrive
Smithfield, RI
This is a pic of the 1966 1/2 hp industrial rating. Cord is spliced in the middle and a 220 plug is on the end. Need to revert back to 110......???
drivesitfar
Belt: I wish you were closer cause i've been thinking of changing my industrial model 1/2's to 220. until some of the experts chime in I think if I recall correctly that the wiring diagram is under the bottom plate if you want to rewire it back to 110. if you can plug it in a 220 and tell me (us) how it runs i'd appreciate it. a year or two ago we had a long discussion on this thread about changing 110's to 220's if you want to look for it.
good luck and nice find!!
torqueman2002
SE Michigan
This is a pic of the 1959 1/2 hp industrial rating. Cord is spliced in the middle and a 220 plug is on the end. Need to revert back to 110......???
Belt - like Drives ^^ said, there is probably a dual voltage wiring diagram under the bottom cover.
I may also have a picture, if you can post the model number.
Nice find!
:beer:
Negen
Seatltle WA
Are you sure that is 1959? Mine is identical and stamped 1969 on the inside of the bottom plate. Or did they just look the same adjective that long. I know mine is aluminum where some are iron. Mine also has dual voltage diagram on the inside.
Sent from my G8141 using The Garage Journal mobile app
beltdrive
Smithfield, RI
I do not have a way to plug into a 220. I have not seen the unit run...bought it on faith. But i ALSO GOT in the package a Red wing huge jelly-bean shaped 1950'sish buffer that hummed really sweetly and a delta 1950s scroll saw - with belt drive motor in a cabinet - in minty condition. 200 for all, including a pile of clamps and some old scrap hardwood.
beltdrive
Smithfield, RI
If yours is aluminum it is 69ish I would think. This one is the old cast iron. The switch should be different among other things. The date code on mine is 19590
beltdrive
Smithfield, RI
I was incorrect on the year...in looking at this (i just now unloaded it) it has a stamp of 1966 on the bottom. I do have a coupl 1/4 blocks that are 1959...really heavy and spin for over a minute after shut down.
So I dont have time to get to it today but I will take the tray off the bottom tomorrow and see if it says anything. Does your 69 look exactly like it??
torqueman2002
SE Michigan
Belt - I have these pictures of a model 397.19590, like yours.
I'm guessing the mfg date is 'SEP 17 1978'.
rporonga
That one is a 6" wheel.
Thanks for the info. Indeed, it had 6"x3/4" wheels. I ended up buying it. Now I have a couple of questions regarding restoration (397.19430, 5.1 AMP, 1/2 HP)
The sheet metal center part has some rust in the top and back. I was thinking of repainting this part. The label is in good shape with no rust or bubbles around it. Should I just mask it and paint around, or remove it for painting? In the latter case, what is the best approach for removing the adhesive label so that it does not show crease marks from peeling it off?
One of the eye shields has both plastic tabs broken. I have the pieces and could try gluing it back, but it may not be safe. Are there any replacements for these plastic eye shields?
Thanks!
beltdrive
Smithfield, RI
wow! thrilled to see that diagram. I finally had a chance to open the bottom...and nothing diagram wise.
torqueman2002
SE Michigan
No way that is 78....more like 68....the 70s are much different. Thanks for the diagram!!
That's my thought, too. The stamp is very difficult to make out, and the cover may not be original.
Hmm. I noticed some differences between my 397.19590 and yours.
My Block's badge/label is a 'Crown Top'.
From what I can make out from your picture, the start-up relay appears to be a different design. See my diagram above.
Close up of my Block.
These may be minor revisions, but caution should be used when using the above diagrams for your application.
If I find a diagram closer to your style relay (or the style I think yours uses) I will post it.
May be you can post a pic of your relay with more detail?
beltdrive
Smithfield, RI
Here's pics of the 66. I believe the crown top to be earlier.
beltdrive
Smithfield, RI
In the same buy, I picked up the homecraft scroll saw with cabinet and motor, red wing buffer, craftsman grinder stand, and the 66 grinder. 200. So many deals....and so little space left in my garage and basement...
torqueman2002
SE Michigan
Belt - ".... so little space left in my garage and basement..." That sure sounds familiar! LOL
Nice bit of shopping ^^.
Your Block's relay is one I haven't seen before. I am not sure how it might or might not be like the one I posted. So I'd proceed with caution.
These are potential relays and function differently than the relays used in cars/trucks.
BTW - I looked through several dozen pics I have of various HP & model Blocks and I didn't see a relay like yours or a diagram.
I will search for the info. I have on how these potential relays work and see if I still have examples of how the internals are laid out.
OK - Here's what I have. Hope it helps.
It is my experience, the dual voltage Blocks are of the "Two Circuit" design.
4-terminal /2-circuit relay, similar to the m-397-19590 Block I show above.
3-terminal /1-circuit relay
Another 3-terminal /1-circuit style relay.
démarrage = start-up |sont = are
torqueman2002
SE Michigan
I found a YouTube video of a down and dirty grinder restoration, complete with a re-winding of the stator!
Warning - non-Block content. :)
<a href="<iframe width=" 560"="" height="315" src="https://www.youtube.com/embed/W7iSj_b3-xc" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen=""><iframe src="https://www.youtube.com/embed/W7iSj_b3-xc" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen="" width="560" height="315" frameborder="0"></iframe>
LesserSon
PA USA
Wow, holy cow, etc! The poultry clucks at the very end say it all: I am way too chicken to EVER try that.
Three comments:
That guy has been building motors all his life.
Unless you were incarcerated or marooned AND had free access to all the tools and materials, it would NEVER be cost-effective.
That particular green is a terrible color choice.
But, it DOES demonstrate that NOTHING is ever “beyond repair.”
exmaxima1
Midwest
Three comments:
I agree that the color scheme is less than appealing. Running a pair of grinding wheels with no guards just makes my sphincter pucker....
jonshonda
Wisconsin
I was able to utilize my dad to buy this pristine 1/2hp setup. Bought it from the original owner who stated it had maybe been used 4-5 times.
I really want to get some eye shields that have the metal frame around them, and I'm sure torqueman2002 has some nice examples that would really finish this setup off!
<a data-flickr-embed="true" href="https://www.flickr.com/photos/154822526@N03/45924012501/in/dateposted-public/" title="Grind1"><img src="https://farm5.staticflickr.com/4910/45924012501_76631ae02c.jpg" width="314" height="500" alt="Grind1"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/154822526@N03/32052932788/in/dateposted-public/" title="Grind2"><img src="https://farm5.staticflickr.com/4867/32052932788_c999efda6f.jpg" width="314" height="500" alt="Grind2"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/154822526@N03/45924012281/in/dateposted-public/" title="Grind3"><img src="https://farm5.staticflickr.com/4817/45924012281_f52cb7f209.jpg" width="413" height="500" alt="Grind3"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
bubinga
Thanks!
Someone in the Know (more about R&R-ing the label) Will Jump in.
If It were me, these days, I'd just mask it and paint it, and be done with it.:thumbup:
SwampCat
Thats an official " YOU **** "
torqueman2002
SE Michigan
torqueman2002
SE Michigan
Three comments:
There are a lot of so called 'tool restoration' YouTube videos that are little more than a clean-up and repaint.
What impressed me was/is this guy knows his stuff and he has that funky whirligig coil winding tool.
Other than the stator rewinding tool, he does a lot with very little.
I agree, it looks like he's been doing this for a while.
Not my choice of colors, either.
Maineiacmoose
Maine
I'm just going to leave this right here for now.... More to follow.
jonshonda
Wisconsin
Funny you should mention that.
How do these look. They are the larger metal framed eye shields, I think.
Good price too - $25 for both AND you get the 1/4-HP m-115.19500 pre-Block free!
:beer:
It looks like they would clean up well. Let me know if you have some laying around! I owe you at least one purchase for all the work you put into previous email exchanges! :thumbup:
cajunfirehawk
Ms Gulf Coast
SwampCat
:D
I'm sure its been covered dozens of times before, but can I trust the original grinding wheels that come with it? What do I look for if I intend to use them?
One test is to put loose stone wheel on a screwdriver, like a shishkabob, hold the handle, use another screwdriver handle and strike the stone. If it rings true, its probably good. If it rings dull or flat, toss it.
