New pole building build thread, need ideas and thoughts.
silverram323
North Branch, MN
Hi G.J Crew, I have been lurking sine 07-30-2014. I love all your ideas and expertise you share.
Im Currently having a building built as we speak. They should be done this week.
The details are, 80' wide, 64' deep and 16' with a 8' leanto for my firewood.
I will be using half the the barn for my shop / man cave.
So that will be 40' x 64.
I will be doing infloor radiant heat, and be putting in a two post shop lift (10k).
Im currently researching info on infloor heat, vapor bearer, foam, insulation, supporting pipes and boiler, Lights, fans, air conditioner, electrical, air compressor line setup, and erosion control.
I hired an excavator for the pad work and he hauled in 73 dump truck loads.
The pad is 10' wider then the building, and its just over 6' tall in the back left corner.
silverram323
North Branch, MN
Material showing up and squaring up the building.
silverram323
North Branch, MN
My pictures are all scrambled up during the transfer to the computer so its fun sorting it out.
anyways, after the pad was done, and before the building was started, i ran water, electric and my wood boiler lines to the shop.
I dug up my well, and put in a tee and a curb stop so i have water for a slop sink and washing vehicles.
Water is 8' down, boiler line is about 4' and electic is 2'.
silverram323
North Branch, MN
Drilling hole, pouring concrete, tipping posts and leveling posts.
silverram323
North Branch, MN
Finished trusses and started roof tin.
silverram323
North Branch, MN
I put in my vertical foam boards, They are 2" thick and 2' down from projected floor height.
silverram323
North Branch, MN
Tyvek walls, and starting to put up tin and setting windows.
silverram323
North Branch, MN
blue print drawings
silverram323
North Branch, MN
inside of the lean to was tinned, and i was able to set up my boards so i can pack it full of firewood for the season.
I cut spacer boards so the plywood wouldn't rest on the building and damage it. I pulled the tin screw and replaced it with a longer wood screw. You never know when plans change so i wanted to be able to reverse it without damage.
silverram323
North Branch, MN
As of 20 minutes ago, these are current pics.
hopefully garage doors will be on by Friday.
rattle_snake
Chandler, AZ
Sure, A/C is common.
Not sure why anyone would need a heater though... anyhow what's the funny looking white stuff on the ground?
silverram323
North Branch, MN
I need a heater because it’s cold out.
HoosierMark
Southeast IN
Don't forget to plumb for a bathroom. Maybe you complete it, maybe not but prep for it. You can always put in a simple septic for it in the future. I put some electric pvc pipe in my floor for putting wires to a work bench. I did not want electrical drops so I picked several spots and put the tubes under the concrete. I also put a few pieces of 2 x 2 steel in the floor so I could have anchor points. Just things you might want to consider.
silverram323
North Branch, MN
I like it, thanks
Kevin54
MEMBER EMERITUS
Urbana, Ohio
How huge is the shop/mancave going to be????? That barn is huge!!! And if you're going to use half as a shop/mancave....I think I'd add a few pool tables, a couple big screen TV's and have the Rural Local bar!!!!
silverram323
North Branch, MN
Ceiling is almost done.
silverram323
North Branch, MN
Building is done till spring, then I’ll finish it off.
silverram323
North Branch, MN
I got some lights mounted and wires ran.
I don’t like the looks of conduit on the ceiling so I ran all my wires above the ceiling. It’s more work but I think it looks cleaner
silverram323
North Branch, MN
I bust my a$$ this summer and I finished the inside of 1/2 of the pole building so I have a nice shop now.
