I thought it would be fun if we used our digital calipers to check the tolerance of different socket brands. Using 10mm as the baseline as its a very common size.
I'll start:
Stanley W86-098B: 10.14mm Measured by Noid
Gray (Canada) MTL10H: 10.08mm Measured by Noid
Koken 3800MZ: 10.04mm Measured by Negen
Koken 3400MZ: 10.04mm Measured by Negen
Results without pictures:
Astro Pneumatic 10mm Brake bleeder socket 12pt - 10.31mm Measured by Negen
Carlyle mid-depth 1/4" - 10.13mm Measured by Spacey_G
Carlyle deep 3/8" - 10.10mm Measured by Spacey_G
Cornwell 3/8" - 10.23 (well used) Measured by larry_g
Craftsman 1/4" - 10.20mm Measured by larry_g
Craftsman 1/4" - 10.15mm Measured by larry_g
Craftsman G-series shallow 1/4" - 10.20mm Measured by Spacey_G
Craftsman V-series shallow 3/8" - 10.26mm Measured by Spacey_G
Craftsman S-AC series shallow 3/8" - 10.11mm Measured by Spacey_G
Craftsman Laser etched shallow 3/8" - 10.14mm Measured by pipsters
Craftsman - 10.15mm Measured by Yarpo
Gear Wrench - 10.18mm Measured by Yarpo
Gear Wrench 1/4" deep - 10.16mm Measured by TwoInch
Gear Wrench 3/8" deep - 10.14mm Measured by TwoInch
Gear Wrench 3/8" mid length - 10.16mm Measured by TwoInch
Gray (Canada) 3/8" MTL10H - 10.08mm Measured by Noid
Grey Pneumatic - 10.13mm Measured by Yarpo (impact)
Harbor Freight - 10.26mm Measured by Yarpo (impact)
Harbor Freight Pittsburgh Pro 1/4" - 10.16mm Measured by Zewnten
Koken 3800MZ 3/8" - 10.04mm Measured by Negen
Koken 3400MZ 3/8" - 10.04mm Measured by Negen
Malaysia 1/4" - 10.14 Measured by larry_g
Pittsburgh 3/8" - 10.12mm Measured by Negen (impact)
SK shallow 1/4" - 10.12mm Measured by Spacey_G
SK wobbly 1/4" - 10.16 Measured by larry_g
SK deep 1/4" - 10.19mm Measured by Spacey_G
SK shallow 3/8" - 10.16mm Measured by Spacey_G
SK shallow 3/8" - 10.16mm Measured by pipsters
SK mid-depth 3/8" - 10.16mm Measured by Spacey_G
SK shallow 1/2" - 10.20mm Measured by Spacey_G
SK deep 1/2" - 10.15mm Measured by Spacey_G
Snap-on New - 10.127mm Measured by equitiesguy
Snap-on Used - 10.127mm Measured by equitiesguy
Stanley W86-098B 1/4" - 10.14mm Measured by Noid
Stanley - 10.11mm Measured by Yarpo
Williams 3/8" - 10.109mm measured by Zewnten (impact)
If you see your sockets in the list, please still measure them so we have a bigger data set!
I will add in Koken and Blue point at a later time from my collection.
To keep things consistent remember to use the inside measurement arms, measure middle of flat to flat and measure then slide the arms out to record the number as to stay consistent for pressure. If the number changes as you're sliding it out, measure again.
I'll start:
Man you guys over think tools I have been a professional tech over 25 years and I just buy decent quality stuff and use it . If it gets used every day its probably Snap On if not then another cheaper but quality brand. I have not had many issues with my tools rounding bolts or nuts unless they were already severely rusty or someone else already did it. but I guess that is what GJ is about so have fun
