Bulk air hose
aczr2k
NW Minnesota
Good hose like Parker 801 is expensive... but it is worth it. You most likely will not get 250' of continuous hose on a roll.
jjkrjh
We purchase a lot of different hose from PPE at work. Here is a link to the index. Click on upper arrows to change pages. They give you general info. to help narrow down what you are looking for.
http://www.ppe.com/ppeindex.htm
PT Doc
With 3/8” diameter @250’, how much pressure drop can you expect at the business end?
C
cvairwerks
Within hearing distance of Texas Motor Speedway
PT: Don't have to worry about pressure drop. Flow rate would be the normal concern. In this case, a couple CFM at 90 psig is all I need. This is going to be just a service hose for the far end of the property. Right now, if I need some air out there, I've got to haul out the portable compressor, 150' of hose and a 50' extension cord to run it. Kinda disturbs the neighbors at 3 am when I'm trying to get loaded up and gone by 4 am.:bounce:
PT Doc
C
cvairwerks
Did the portable tank thing for a couple of months before I was able to move a small compressor up from the other house...Was a huge pain and took way to long every time.
Noid: Not going to be using a spring loaded reel...doubt they make one that big, but for enough $ they might...:spit:
We've got some spring loaded electrical reels at work. With about 60' of 12/3 industrial power cable on them, if they pop loose and get any speed going, it's dangerous. I've seen one cut loose and ****** a 100+ pound cart and it's contents about 25 feet and throw it around. Not a pretty sight when it's got a custom built maintenance computer flying across the hangar floor.
noid
You know what they say, safety third.
Do it.
Provincial
Near Salem, OR
Find a 30 gallon air tank from a "dead" 175 psi gas-drive air compressor. Mount it on a Harbor Freight 1,000 lb. Mesh Deck Steel Wagon, along with a 25 foot air hose reel. Charge it up to 175 psi and you have quite a bit of air at 2 cfm @ 90 psi. You can even tow the loop-handle version with a pintle hitch.
1Garageman
Columbus, Ohio
Would this work?
Flexzilla Pro Air Hose, Bulk Plastic Spool, 3/8 in. x 250 ft, Heavy Duty, Lightweight, ZillaGreen - HFZ38250YW
https://www.amazon.com/Flexzilla-Plastic-Spool-Lightweight-ZillaGreen/dp/B007X6MGU6/ref=sr_1_10?ie=UTF8&qid=1542977395&sr=8-10&keywords=250+ft.+air+hose
C
cvairwerks
The whole idea behind this project is a permanent installation, and eliminate the portable stuff. Done the portable stuff for too many years and tired of it.
Saw the Flexilla, but haven't seen or played with field installable fittings yet. I bought a spool of the Goodyear red hose stock back in 1982 and made up hoses from it. I just trashed the last of those hoses this year. I've got some Legacy SmartFlex hoses, but don't really like them, as they are too easy to kink and catch on things.
sberry
Brethren, Michigan
If this was routine I might be tempted ti find a roll of 1/2 rolled pvc, dig it in shallow, turn it on when needed. Not sure if they make it smaller but with 1/2 you wouldnt know you were not next to the comp. They make it in 80/100/120 psi. Have never seen it blown out.
