off topic plumbing question
jyabs7
South Dakota
I know not directly garage related unless you're super fancy and have a shower in there but...
bought a new house and the shower drain is disgustingly rusted. I want to replace it. However, inside the drain there's no "cross beam" type thing for a drain removal tool, and no notch in the flange, or anything alike to be able to spin it out. How do I know if I have a press on flange that's not replaceable?
J
jyabs7
South Dakota
J
jyabs7
South Dakota
If it makes a difference, this room is on a slab so no crawl space or cheap access to the underside for me. What's odd too is this room isn't all that old. Maybe 10-15 years old, so not like stainless parts weren't in existence when they put the shower in. it had a cheapo press on screen as well
J
jyabs7
South Dakota
i actually tried that haha, i just couldn't get it to seat right. I actually got it to come out! it was a normal threaded one (albiet cheap version). Method was using a roofing hammer with the claw inside the drain and using the handle for leverage to turn the drain out. It took quite a few trials and the old drain eventually split into pieces at the threads, but I was able to scrape all of it out of the drain. new one went in like a glove and we are good to go. A little bit of soft scrub on the tub and i won't feel like i'm going to get tetanus or something ha.
So many small projects in the house itself hasn't let me get to the part i'm most excited about, a 30x40 garage ugh.
Kaizen
New England
Man no access underneath and you knocked it off? Ballsy move. I’d have let it rust to oblivion before attempting. Last one I did like that had to open the ceiling and ended up having a 120 year old hand made copper trap. Pretty cool but what a job
J
jyabs7
South Dakota
The one in my old house I had to gut damn near the whole bathroom because the pipe underneath cracked and I couldn't get underneath, and had to pull the tub...I was literally all set and dragging the tub when the side of it separated from.the rest of the tub. I didnt care at that point, figured I was replacing it anyways, until I realized the side of the tub was hinged and meant to lift up for easy access to the plumbing. I couldn't believe it, never saw anything like it.
HoosierMark
Southeast IN
I have one of the tools in post #10 . It has worked for me numerous times. I have 12 drains on concrete slabs plus 12 more on second floor. Works every time for me. It is left hand threaded and simple to use. Once in a while I need a breaker bar to loosen it and I am afraid I will rip the tub but I have been lucky so far. I only learned about this handy tool a few years ago so I am sharing although the poster has solved his problem already.
