Hi,
I was referred to this forum by a good friend to ask a specific question; however, I'm really glad he made me aware of it as I've already learned a lot perusing the content here!
I wish I had been aware of this forum during a project to turn a coat closet into a server closet. Note the vertical mounting orientation was required because the servers are too deep for the closet (horizontally). Also, I should note that I beefed up flimsy metal studs primarily because directly behind the closet exists a custom closet I installed. While plywood on a french cleat would probably have been OK without the additional 2x4s and 2x6s, I figured it better to over-engineer initially instead of figure out I have a problem later.
The point of my post - while my solution works - I'm nowhere near as knowledgeable as forum members here - and I'm just curious how you guys would have done things differently / where I screwed up? (Again, I'm quite fascinated with the content here!)
Here is what I did:
Part of my thinking here was that when I sell my condo, minimal effort is required to revert to salable condition. The plywood panel can be removed simply by lifting it vertically, the french cleat on the drywall is easily removed and only a few holes need to be patched, and I doubt most people would even catch the fact that the "light" is an exhaust fan (and probably no need to remove).
Here is what I did:
- Removed drywall on all sides of closet.
- Bent lips of steel studs to allow insertion of wood 2 x 4s (verticals) and fastened them in place.
- Added wood 2 x 6s (horizontals).
- Inserted Rockwool SAFE'n'SOUND sound abatement insulation on all 5 sides of closet. (Servers belong in datacenters and get noisy)
- Ran armored electrical cable to the ceiling and side, and installed a bathroom exhaust fan on the ceiling, and switch of course. (Servers exhaust serious heat and it would overheat or run too hot to my liking without proper airflow).
- Replaced drywall.
- Used a french cleat to add a plywood panel.
- Mounted vertical server racks to plywood panel.
- Increased gap under closet door to 3/8" to allow for air inflow (negative pressure environment created thanks to the exhaust fan, even at a paltry rating of 110 CFM).
