How to Remove These Retaining Clips?
bulletpruf
San Antonio
Fellas -
I need to replace the starter pawls on a Jonsereds chainsaw. The clips to hold them on are difficult to remove. It looks like you could get something in the t*ts on the end to spread them, but I can't get a circlip/retaining ring pliers in there to open them up. And when I push them off with a flat tip screwdriver, I break the t*ts off.
Am I doing something wrong here?
Thanks,
Scott
snyder
Baltimore md.
It looks like a square tipped screwdriver would fit in the gap and twisted to spread them open. Might have to grind a custom one.
gatlibs
N/A
I would take the springs off first. What set of snap ring pliers were you using? I like the Imperial ones in blue which are re-branded as everything from Lang Tools in orange to Wilde in purple and many other colors and brands. If you don't want to try a different set of snap ring pliers, then maybe try going over one side and under the next side with a pick to spread the ring.
The breakage could just be the size and wear on the part. I'm assuming that the new pawls did not come with new retaining rings.
seber
Deep East Tx.
Those are meant to be removed by inserting a sharp screwdriver between them and turning to spread them. Normally the multi-tool that came with your saw would be the proper size but YMMV.
Evan(CA)
Looks like either a screwdriver or pair of c clip pliers should easily pop them off.
bulletpruf
San Antonio
Thanks, fellas. As mentioned, I don't think I have any snap ring pliers that will fit in that teeny hole. But I may be able to get a screwdriver in there to pry it open, especially if I can lift the clip off the pawl a bit.
LXCam
Screw driver and a magnet to catch it before it finds its way to narnia
Looking at those closer it appears you could spin them over to the thin side and either get a better grip with some snap ring pliers or at a minimum, slide a flat blade down enough to spread them easier.
KnurledNut
n/a
Those are Type G grip rings.
They make dedicated pliers just for assembly/removal.
They would be hard for a consumer to acquire, but you could possibly get them from a Seeger distributor.
I would take a pair of needle nose and grind or file the tips to the shape needed.
Here is what they look like:
MoonRise
Left hand hold a rag over the clip to keep it from flying off to who-knows-where, right hand puts flat-blade screwdriver of appropriate size into the gap between the ears with screwdriver shaft parallel to the axle-pin axis and applies slight torque on screwdriver to open the ears just enough to slide the retaining ring out of the groove. Done.
Don't pry 'up' on the ears to get the retaining ring out of the groove, you need to just very slightly spread the ears open to then get the ring ID to expand just enough to come out of the groove.
Or you can wedge two flat blade screwdrivers down into the ear gap to again open the gap just enough to expand the ring ID enough to come out of the groove.
Or go and get the 'special' pliers. :lol:
bulletpruf
San Antonio
Good tip on the magnet!
Yes, you can spin 'em over to the thin side for a bit more room to get a screwdriver blade in there.
thanks for the input
bulletpruf
San Antonio
Winner, Winner, Chicken Dinner!
I will check my snap ring plier drawer again to see if I have something that might work. I have some with the removable tips that might have a pair that will fit into the tiny gap.
A pair of modified needle nose might do it, too.
And I'll need to reinstall a pair, too -- they're made especially for retaining a piece where there's no groove, unlike an e-clip, which wouldn't last long here.
Thanks
bulletpruf
San Antonio
That will work, but now that I've realized there's no groove to worry about, it might be a bit easier.
thanks
bulletpruf
San Antonio
Ok, so I had already gotten the clips off the original flywheel yesterday and boogered up the clips in the process (broke t*ts off the ends).
Tonight my simple task was to remove the clips, pawls, and springs from another flywheel and transplant them to the flywheel on the saw that I'm working on. Easy enough, right? And I even found a pair of snap ring pliers that would fit into the small space in the clips. Hooray!
And then I spent about a half an hour trying to get the clips off. And failed. Again and again. These suckers are strong! And while they're designed to be retain something without the need for a groove in the piece they're hanging onto, the flywheel is aluminum, so they eventually wore a groove in it, making it tougher to get them off.
I eventually just got the boogered up clips and re-used them. I had to close them in a bit and tap them off because they had wallowed out some when I removed 'em. Not perfect, but they'll work.
Appreciate all the input. If anyone knows where to get a Seeger tool, please let me know.
Scott
bulletpruf
San Antonio
So the Seeger tool arrived in the mail! Hooray! It wasn't cheap, but good tools generally aren't!
And as soon as I ripped the package open, I went to the garage to finally conquer the clips that had laughed at my feeble attempts to remove them. It was time to show them who the boss was!
And then this happened...
Sh*t. I wasn't even able to remove one. I'm sure I could straighten out the bent tip, but I suspect it will bend again.
Back to the drawing board...
bulletpruf
San Antonio
bulletpruf
San Antonio
I think I ordered the wrong pliers -- too small/weak, I think. Going to verify the size of the clips and, if I ordered the wrong pliers, I'll order the larger ones.
Thanks
KnurledNut
n/a
Thanks
They have 5 sizes. The ones you got were the smallest.
Im curious, is there a groove on the shaft that the clip fits in?
Typically these clips are used in applications with no groove.
bulletpruf
San Antonio
Yeah, after doing a bit more research, these are the clips designed to be used on a 7 mm shaft/post, and they have an inside diameter of 6.7 mm. According to Seeger, I should be using the size 1 pliers, not the size 0. I'll get some ordered.
Also, there is a groove on the shaft, but I'm pretty sure it's created by the hard steel clip with an ID of 6.7 mm on a softer aluminum post with an OD of 7.0 mm.
From Seeger, "Seeger grip rings are designed for the assembly on shafts without a groove. Thanks to their large radial width (b) and thickness (s), the large elasticity of these rings makes them suitable for absorbing high axial forces. Parts to be secured can be installed without end play and be re-adjusted by shifting the Seeger grip rings into place. This style of grip ring is the only self-locking Seeger-Ring that can be dismantled without destroying the ring."
Thanks for the input.
Scott
Milton Shaw
Those clips are very similar to the clips on older drum brake cars emergency brakes levers. I would use a sharp scratch awl and ding the bottom of the "U" shape and then drive them off with a small hammer. A sharp pair of slip joint's pliers would grip the ends to put them back on. Worn out pliers would slip and not work, same with the scratch awl
