Kaizen
I had another thread about starting my own oil burner maintenance. Part of that
Plan was to get a pro with a combustion analyzer to make sure I was at a good starting point. As the winter set in quicker then expected I had to take this guy. After I explained I had cleaned it all and just needed a combustion test he quotes me 800 bucks. I got him down to 420 and had him do a nozzle and internal filter change. Ridiculous right? Had no choice.
Anyway he said my draft after I fixed my chimney was too much. It’s a seven inch pipe going into an unlined 8x8 chimney. He said this will **** the fire out and hurt efficiency? Bs?
Also my smoke test was almost zero. Very clean. He said it should be a little dirty or it hits the back of the furnace?? Thought that was air control?
Third he told me my clean burning boiler needed to be replaced to the tune of 13k even though it had an 84 percent efficiency test and the sticker was max of 86. If maintained properly why does efficiency go down?
...sounds high but without seeing job,boiler size..
