Frank Mossberg Salesman Board No. 600
That letter opener is way cool. :thumbup:
The detail on the aerial view of the plant is really quite impressive.
Private Lugnutz - you've got everything I had on Mossberg, and I went through all of those twice looking for anything that resembled "display" or "merchandiser" and sent those all to you in the first go-round.
I'm wondering if it's possible he's got a one-off deal, or if it's simply a case of me not having yet stumbled across the right catalog page. (More likely the latter.)
:lol: no kidding? :lol:
.... and here I thought I'd gotten that "list" all completed and I've added no fewer than three new names in two days... the one I just emailed to you this morning is already out of date! :lol:
LesserSon
PA USA
Lugz, yesterday I spotted a FM no361 (is it an oil pan plug tool?) bundled with a C’man underline speeder at Jake’s. Something told me there was a reason to buy it, but I couldn’t recall why, so I regretfully left it. What tools are you missing on this board?
P
No worries, LS - I have the No. 361, which is, ironically, a lug nuts speed wrench! :lol:
Here is a visual reference:
MISSING/NEED:
On the top left...
- No. 652 universal joint tool (for installing steerage knuckles)
- No. 624 ratcheting connecting rod wrench, 5/8"
- No. 638 single end wrench (wrist pins)
On the left, in the middle...
- No. 676A double end wrench
- No. 634 double end wrench (spring perch nuts)
Down the middle...
- No. 625 single end socket wrench, 9/16"
- No. 2337 tee-handle speed wrench, 9/16"
- No. 650 hub cap wrench
On the right, in the middle...
- No. 622 double end socket wrench, 9/16" square, (crank shaft main bearing bolt heads)
twertsy
Reedville, VA
MISSING/NEED:
On the top left...
Down the middle...
You'll have to dig better next time you come. I know I have a 624 and 650 for example. I don't think we hit the drawers with the specialized wrenches in them the last time you were down.
P
As I was saying on the Garage Sale thread, I ran into a crapload of fixed socket era tools at the flea market this morning (see Pic 1). The seller cleaned out a 100-year old dilapidated garage. He said everything was hanging on walls with a light fuzz of rust from moisture. Mainly Mossberg, Walden, and Blackhawk, mainly speeders, tee handles, connecting rod wrenches, and those double offset hammer head style wrenches.
First thing I looked for were things I needed for my No. 600 Salesman board (Scroll up a few posts...). I was happy to find this 676-A (see Pics 2 & 3).
When I got it home and cleaned it, I noticed it was a different variant than the hammer head type shown on the board. There are bends in the shank rather than the sockets being fixed to the end of a straight shank. Probably a little later than the board.
r_olson_06
SD
Damn. That is a crapton. I see a pail of them about once a year but never in that amount. Is there any Plomb fixed speeders in that batch? Hit me up if you find any you are willing to part with. I have one lonely one that needs some friends.
P
No Plomb. Almost exclusively Walden, Blackhawk, Mossberg, Bog (only 1), Indestro (a couple), and a mfgr I never heard of called Fawson. Here is what I culled out today. I was actually short on cash and I am hoping to go back and grab more tomorrow.
Phew! Thank goodness this doesn’t fit your board!
Oops! I meant, figured I’d post this here. :lol:;):)
It’s a 1/2” dr No.360 despite what the tag reads.
P
That's a cool one with the wood grip and knob.
Here's another empty spot filled on my salesman board from that lot. No. 650 Hub Cap wrenches. Strangely, none of them are marked Mossberg or < M >. But I'm not going to split hairs. Whether these were made by Mossberg or someone was making them for Mossberg and all these outfits (they're simple enough - crude pressed steel...), there's no doubt they're a match.
P
And I am completing the trifecta for filling three empty spots on my No. 600 Salesman Board from the flea market lot with this 2337 Tee-Handle wrench.
P
I'm slowly getting to the rest of the Mossberg pieces. These don't go on the No. 600 Salesman Board, but I'm going to post them here anyway.
The No. 6080 FOR FORD V-8 CONNECTING ROD NUT Tee handle wrench is a very early and crude approach to Mossberg's connecting rod wrenches. They would make them with a little loop handle and later with a ratcheting end.
I have never seen the Michelin Wheel M'F'D BY BUDD wrench before, in the wild or online or in a catalog or trade journal. Maybe the coolest piece in the lot.
Budd made wheels for Dodge, Ford, Studebaker and others and, in 1923, made a new and improved version of the Michelin-style disc wheels with a steel nut instead of a brass nut, in cooperation with Michelin. Mossberg must have made the rim wrenches for them. I wish it wasn't missing the other end piece, because I'm not even sure what it was, never having seen one before. Guessing some kind of simple rotating end knob.
P
These 1300 series "T" handles - the main object of my desire in that fixed socket wrench lot at the flea market - don't hang on the No. 600 Salesman Board, either, obviously. I am pretty sure they're older than the board. They were probably made before 1919. Before Blackhawk and Snap/on even existed, and before their own detachable heavy duty sockets existed. Like their early detachable sockets, they all have a 1/64" oversize tolerance, and they're marked that way.
The last two digits in the model number is the nominal size of the service opening expressed as a number of /64th's! For example, wrench No. 1357 is 57/64".
The only literature I can find that's close on these are ads in hardware store catalogs for the later 2300 series "T" handles, which had the same model numbering scheme (with a different prefix but the last two digits still indicating the number of 64ths...), but the expressed nominal sizing of the opening adhered to a more traditional scheme, and those apparently didn't go up as high in service opening sizes as these 1300 series go.
P
This doesn't go on my No. 600 salesman board, but this thread has been expanded enough to Mossberg in general that I'm going to put this Ford reverse gear ratcheting wrench here.
P
Here is another Ford hub cap wrench stand-in (not made by Mossberg) for my Mossberg No. 600 board. (See post #58.) That makes six (6) of them now, none marked Mossberg No. 650. :lol:
This is a goodie, though. A Ford script (8-11-1920) Model T T-1349 with what I suspect is an early Moore Drop Forge mark.
r_olson_06
SD
Here is another Ford hub cap wrench stand-in (not made by Mossberg) for my Mossberg No. 600 board. (See post #58.) That makes six (6) of them now, none marked Mossberg No. 650. [emoji38]
Do you have a group shot of the board with your updates?
Sent from my XT1710-02 using The Garage Journal mobile app
P
Thanks for the prompt, Roy!
UPDATE:
MISSING/NEED:
At the top, on the left...
- No. 624 ratcheting connecting rod wrench, 5/8" (the place-holder hanging there is the non-ratcheting version)
At the top, right in the middle...
r_olson_06
SD
UPDATE:
MISSING/NEED:
Looking good. Narrowing in on the finish line.
P
Huge shout out to GJ'er wcemail, who was willing to sell me a Mossberg 624 ratcheting connecting rod wrench for my No. 600 Salesman Board. He just found it a few days ago. His thread querying for info (and my shameless inquiry about its availability :)) is linked here. Good dude.
Good demonstration of just how hard it is to fill this board, too. I don't know if it's earlier or later, but it's not the kind with the twisted handle that is shown in the ads or on the original graphic layout that is still on the back of the board. (If you scroll up to post #69 you'll see what I mean.) It's offset, and it ratchets, but it has a straight handle with a little paddle shape to it. Pretty cool, actually. Precariously perched. But a great stand-in, and if I never run into one with a twisted handle, I won't care too much.
Thanks, again, Warren!
:beer:
MShaw
York, Pa.
I do clock repairs and one of the least intrusive way to preserve a label is to cut a piece of plexiglass and mount it covering the label with a few small screws. Preservation without the danger of damaging label.
Targa68
Norway
Hi All
Another nice bike wrench, "STERLING" NO1
