I'm looking for the screw on adapter/chucks that are on the bottom right of this picture. The one that's crimped onto the air line, that screws onto your valve stem.
I work in a heavy truck shop and am trying to build screw on adapters at varying angles (straight, 45*, 90*, 135, straight extended) so I don't have to hold the traditional air inflators onto the stem. You'd be amazed how tiring that is filling 8 semi tires from 0-100psi for a half hour.
I currently have the clip on adapters, but they don't hold the stem and are too bulky. Screw on is foolproof.
They're readily available on cheap hoses, but never standalone!
If I'm unable to find, I'll be forced to order some of these flexible valve stem extensions, cut one end off and add an adapter to the existing hose length.
I'd prefer to build my own custom so I'm not limited by hose length. Any fittings close to the stem adapter in a tight space between duallys can cause havoc.
This is similar to the standard inflator with gauge that I'll be modifying (the hose after the gauge that attaches to the stem of course! In case I was leaving parts out.
If you know where I can find any I'd be very thankful.
