Sears should have brought ToysRUs. lol
Ironic Sears basically invented Amazon a hundred years ago but they got out of order style sales.
Sent from my iPhone using
The Garage Journal mobile app
The level of strategic wisdom of Sears' management has now been confirmed.
The cross member is looking great Andy, I'm excited to see how it turns out. Funny that you mention the offsets on size and angles from side to side. I know the trans mount itself is off center compared to the trans center line for some reason. The difference in angle was probably because of my lack of extra hands. (Read shoddy workmanship on my part). I have no doubt it'll hold the trans up just fine and be a really cool conversation piece few people will ever see outside of our threads.
JB
I don't think it's shoddy workmanship, but my goal is to match the existing. I do hope you like the outcome. Maybe more work on it tomorrow, depending on weather (bad weather, work inside).
Andy: i think i'm smelling hot melted aluminum?
carry on and have a great day!!
Thanks, Drives, but it was brass.
Nah, I'm all red - but I'm also a Chevy guy, the peak combination.
Although ig you're pretty much an equal opportunity vehicle owner.
55 of 60 tractors are IH here, so I guess I'm red.
4 out of 7 cars here are Chevys, so I guess I'm a Chevy guy.
But only 3 out of 12 trucks are Chevys, and 4 are Fords, how did that happen? 2 Dodges, a Studebaker, a Willys and a Binder.
Crikey! That funnel is a tough object to cast. Shapes like that is most oven done by investment or die. Darn good challenge to figure out getting it to work in green sand. Looking forward to see how the cross member comes out too. The foam part is looking great already.
I'm figuring out it's a challenge. The shape is too long and parallel to withdraw the sand easily. I'm struggling with molding as well as casting.
The foam part has some more work to do, then I hope I can pour it, a failure there means another pattern.
Otherwise hope all is well and you are just too busy having fun and talking to the cows. This is a time for family and social obligations. Definitely keeping me from the shed!
All is well, thanks for the concern! Lot's of opportunities lately. I did make it to my son's 50th birthday party.
That's my little Studekota Granddaughter. She is cool!
Back to the salt mine, err, foundry.
Here's damage to the core sustained removing the pattern. You can see the cracks in the sand at the top and a circumferential one at the bottom.
I had a bolt through the sand but it was firmly stuck to the pattern. I even added a hole in the pattern to relieve vacuum and give me a window to press on the sand (that's what fractured the top).
I decided to go ahead and pour it, defects inside a cover are not that bad and I'm needing to get the heat right.
Well Bob!
Part way through the pour the brass started running out the side of the flask. I hadn't weighted or clamped it before and had no problems. But I hadn't got this much molten metal in it and the hydrostatic force from the liquid metal floated the cope and let the hot stuff out.
As before I poured some of the rest of the charge into the riser hole. Casting does not look too bad for the portion that poured.
The cracks at the bottom were not really a problem.
Just a little brass bled in.
My well did quit the other day. I pulled the pipe this morning and found nothing.
Really nothing. The jet and foot valve are still at the bottom of the well.
And Mr. Genius didn't bother to put a safety rope on it the last time it was out. I don't know whether to try to fish it out or just leave it there. It will probably just stay in the well. The well is only used for watering cattle (and I don't have any penned up) and for the sink in the shop. Going without the sink for a few days is good penitence for not putting on a safety rope.
