Big snap ring pliers for 3-1/2" internal rings?
bimmer630
Ive worked mainly on BMW stuff for over 10 years.. Rear press in wheel bearings have a 3.5" snap ring that holds them into the knuckle. Ive used a Snapon srpc9000a snapring plier, which was the "largest they offer" according to the guy I bought it from..
Anyway these cars are getting older and often I get one where the ring is rusty and these pliers dont cut it for compressing the ring. Also the tips of the tool are much smaller than the holes in the actual ring.
I usually have to smack the ring with a punch first to break it free, When Im dealing with a rusty one.
What is out there that is a little bit larger, with tips that actually fit the holes?
bimmer630
eb50968f928c8890c72faac7eb15c2bb.jpgee3e4f00b1c6114a9ab607a972cb1928.jpga423cf6dd12b90710f7e23bf90e44177.jpg
bimmer630
The SO man actually had those large bluepoint ones on the truck last week.. I didn’t like the price and figured I could find out who really makes them, and pay less. But it looks like gray might make them, (as well as that kit in the red box) and I have no clue how to buy gray tools on this side of Lake Erie [emoji14]
bimmer630
https://intechbearing.com/products/75-lang-internal-external-quick-switch-retaining-ring-pliers
I like these because they ratchet. But I don't deal with snap rings that large very often. I think your trick with the punch is probably necessary when they are rusted in place no matter what pliers you use.
We have a set of those (or similar to them) at the shop that I also tried, to no avail, if Im not mistaken.
I think Ill go for these https://www.zoro.com/proto-retainin...ontent=12738330&utm_campaign=1634220#sku=J364
6PTsocket
I found these. They look pretty heavy duty. Lang Tools 87, formerly known as High Tech.
https://www.tooltopia.com/_img/LNT/LNT87.jpg.
It looks similar to the Gray/Bluepoint. without the case. Maybe Lang is the Manufacturer. At any rate, it looks strong and is available south of Lake Erie.
paulsomlo
Northern Colorado
If you're not adverse to ordering from Amazon.de, you can have a Knipex 4411J4, 4811J4, or a 4421J41 (right angle version) delivered to the USA for $30 or less, all 0.125" tips. Shipping times show about a month, but I've had stuff arrive in less than two weeks. Search "circlip pliers j4" on Amazon.de.
WittHay
Surrey, BC Canada
The Lang 75 or the Blue-Point PRC65A works good on larger retaining rings. I had the older Blue-Point version with the red handles. Skookum built plier about 10" long
  • snap-tool-blue-point-prc65-snap-ring_1_22cc142a34760069e9f42f194da184cd (1).jpg
bimmer630
I ordered the 4811j4 for 30 bucks shipped. I couldn’t find much as far as pics of them in someone’s hand to gauge the size, but the .125 tips and the long-ish handles make me pretty confident
619DioFan
San Diego , Ca.
I can recommend that you should NOT buy the HF large snap ring pliers. got them for some large snap rings on a mazda awd that needed wheel bearings. they bent before the snap ring was even half way closed. and we don't have the rust problem here in cali.
bob15
Northeasten, CT
These Blue Point pliers have always worked well for me: https://store.snapon.com/Interchangeable-Tip-Pliers-Retaining-Ring-Interchangeable-Tip-Internal-15-11-16-Blue-Point--P797295.aspx
paulsomlo
Northern Colorado
The Knipex are almost 4" longer than the snap on that you're using. Assuming the tip diameter fits the ring, I don't think you'll have any problems.
Let us know how they work out.
bimmer630
The Knipex were waiting at the house when I got back after a week long vacation for the holidays.. And they look like they are going to work perfect700186628a75006a2b7e0ecc598af436.jpg726220a9413b9ded140563da42bc6533.jpg
