zmotorsports
That looks pretty damn good from where I'm sitting Cam.
Great job.
Great job.
Will the Jeep be used in sand, mud or snow?
Any reason to think about incorporating a mount for a jack base on the backside of the structural triangle?
Great job.
Little progress. I ended up making the spare carrier out of 1/4" plate with 1-1/4" x 3/16" wall and the receiver from 2" x 3/16" wall. Little loose but I'll fix that. I also offset the mount so you have three inches of difference. That put the bottom of a 33" tire right at the top of the bumper in the lower position. And both the receiver and the mount are run wild for now. I'll cut those down after I finish the jack mount. Then I mocked up the jack to see what looked the best. As low as I could go or at a 45. I'm thinking if I spray bombed it black like Mikes, it'd look waaay better
And once again thanks for you guys input, much appreciated![]()
Why is it that all Californians want to move to Prescott? It's amazing what has happened to Prescott since the "invasion".
And here I thought you were going to build a long tube, mount it parallel to the body on the undercarriage and use it as dual purpose jack storage slash skid plate! [emoji51]
In all seriousness, it looks good Cam! [emoji106]
Hum, dual purpose maybe
Thanks bud.
Sent from my iPad using Tapatalk Pro
I like the rear bumper. Looking good.
LX does do some nice work......
Did you drill a drain hole in the box?
Looks good Cam.
I noticed when I built mine that I had to swing the carrier out just a few degrees more than the tailgate or the gate would make contact when opening. I just added a few degrees and problem solved. Also if you angle the upper portion of the Hi-Lift upwards just a little more, more parallel with the angle support of the carrier, it may clear the taillight a bit more as it will move the foot slightly downward but mine is fairly close as well. I mainly didn't want to block the taillight from view, I wasn't worried about access but the only way the jack will be removed/installed is with the carrier open anyways.
Very nice tough with the insert to reduce rattling. I didn't add anything to the foot portion of mine, the foot is unsupported. The only contact mine has is with the bracket where it attaches.
The jack isn't running at the same angle as the square tube for the tire mount. Scrap it. I'll PM you the address for disposal.
I like it. Here in the swampy southeast I could never leave the jack on the back of the jeep like that, would be a muddy rusty mess. Otherwise I would steal that mounting idea, I like it. I have a 90 Cherokee and my high lift lives under the back seat.
Very nicely done Cam.
As a comment about the jack touching the tire, I actually have my Hi-Lift jack pull into the tire very slightly which acts to help stabilize as well as keep the handle and jack from rattling. I merely offset my mounting bracket about 1/8" inboard of the outer surface of the tire so when the jack is tightened down it pulls into the tire and preloads it a bit. Also worth mentioning is that I only throw my Hi-Lift jack on when we are going off-road or heading out on a Jeeping trip, I don't have mine on the majority of the time but when it is on the Jeep it is rattle free.
I like the design very much and the owner should be ecstatic with the way it has turned out.
Great job.
I really like the offset tire mounting flange. I have my jeep built with no intention of upsizing tires so I do not need the adjustment for future tire sizes. BUT I like the idea of having the tire down low for around town to have visibility out the back; and up high off road for departure angle. This thread is getting tucked away for when I get back around to the jeep.
Nice work, Cam! Looks good.![]()
First one I've personally seen done like that, as always impressed with the skill and level of detail that goes into your work
Lookin' great Cam. Very nice work on that lock assembly. I merely used a toggle clamp but I like the lock and key assembly.![]()
That lock system is sweetFirst one I've personally seen done like that, as always impressed with the skill and level of detail that goes into your work
That is super-slick Cam. I was having a hard time envisioning it when you started the lock assembly but now it all makes sense and looks very clean and tidy. Great job as usual.
Do you have a backstop to keep the swing arm from closing too quickly and hitting the body before the pin can be dropped in place?
Great idea using the cut in half isolator Cam. Those little things come in quite handy in the most unexpected situations.![]()
Now the bumper can be adjustable over time if the rubber wears or gets compressed, by simply adding a shim washer. Brilliant.
