11mm the most useless socket in the world?
vaultdweller
Landrum SC
I use 9 fairly often in textile machinery of Italian and german origin. I have specifically bought about 5 9s in different styles trying to find just the right one. Luckily I do more than half of my buying at a pawn shop that I basically pay flat rate of $0.50/pc from the loose tool bin. Makes accumulating oddballs cheap.
El_Guapo
Globe, AZ
Took apart a small gearbox recently, all the seal retainer bolts were an 11mm socket. Internals were junk, so into the scrap bin it went, and has probably already been melted down and reforged into cheap 11mm sockets.
wssix99
Chicago, IL
So many people are comfortable with their swath of 10mm bolts, but... the 11mm is obviously one better.
When you have a 10mm bolt and you just need that extra push over the cliff, you know what we do? We put it up to eleven.
mailpup
Los Angeles
As already mentioned the BMW intake manifold (at least on the M54 engine) uses 11mm headed bolts and one thermostat housing fastener is 11mm. If you've ever had to work on a BMW, you know the intake manifold has to come off to perform other routine (for BMWs) maintenance jobs.
TonyCH
Finland
Obviously you don't work on anything Japanese
Yes, you are right, years since I touched anything japanese. Mostly european cars, some vintage EU/US cars, mopeds, lawn mowers, snowplowers, bicycles etc.
Catch_22
Nashville, TN
No. I think 20 mm is useless for anything other than filling a peg on a Hansen rack.:wtf:
Truth. I had to order a deep/shallow 3/8th just to keep me from having anxiety every time I looked in my box. It will forever stay in that slot, never to move.
tonyciambrone
Northern Illinois
I would say 33mm is my least used. I don't use 16 or 18 much except when I see a Chrysler product.
9 and 11 are used a lot, but it's always funny to see what guys don't encounter.
As I remember, on my Subaru you needed 8,10,12,15,17,19,21, #2 PH and a couple torx bits.
PR1Gneon
11mm for 1/4" wedge anchor nut.
Sent from my SAMSUNG-SM-N920A using Tapatalk
intillzah
Larned KS
I have an elderly Kawasaki motorcycle, and I swear that bike has nothing but 11mm nuts and bolts holding it together...
BonzoHansen
As seen on FB today...
Spacey_G
If you're just looking for a socket to leave out of a set, why not make it either 19mm or 3/4"? Those are much closer in size than 11mm and 7/16.
greenlizard
Chapin, SC
I used my 11mm socket(s) every time I did almost anything to my N54 equipped 335i. And being an N54 it required regular attention. My 11mm sockets have the same handling marks as as the 10’s and 13’s. I suspect things are engineered with minimum sized bolts for weight and space saving purposes. Goodness knows modern BMW engine compartments are incredibly tight.
57JoeFoMoPar
S. Plainfield, NJ
I never had to change the TFI module on my SN95 when I owned one years ago. I'm sure I'll have to pull the 11mm out for my N55 535i sooner or later.
shockwave
Marietta,ga
I use the 11mm a lot lately on mostly Ford products and 7-16 is very close and can be used instead also a lot of tpms use 11mm
Now a 9mm is really the oddball of any tool box hardly ever used
G
Glassdave
well i'll be damned . . . the 11mm fastener exists . . . but more to the point . . . jeasus i'm outta touch with modern mechanicals lol. . . . for the record i kept the 11mm socket, its close by, just wanted a clean arraingment on that socket rack and something had to go :D lol
Jtels85
11mm for those 10mm engine shield screws under your Challenger/Charger/300 that get scraped up from curbs and bottoming out.
I think my 11 gets more use than the 10 these days :lol_hitti
Yarpo
Minnesota
Just had to use 11mm today! Mitsubishi highlander, some stupid 10mm bolts underneath near the vapor canister, sooooo rusted I thought it was a 12. It was a 10, but 11 got on snug enough to do the trick. Rust, fun stuff.
rustbucket5
i use 9mm more than 11mm. 9mm is common for valve adjuster jam nuts on the small engines i work on
JulianMorrow
Oklahoma
I work on two Toyotas and a Ford truck.
Sizes rarely used: 9mm, 11mm, 15mm, 16mm, 18mm.
Sizes frequently used: 8mm, 10mm, 12mm, 14mm, 17mm, 19mm, 21mm.
Once in a while: 13mm for the oil pan drain plug on my Ford Ranger.
ChrisLS8
All the t bolt clamps and v band clamps on my turbo setup use 11mm nuts as well. Granted it's a case by case basis but lots of people run these as well
f121
UK
11mm is typically used on European cars for fine thread m6 nuts and bolts, to distinguish them from regular m6 with a 10mm head.
The 9, 12 or 14mm I could probably bin and not miss for a while.
gda659
in the forest
I've used the 11mm socket, but never the 9mm.
I bought a Thorsen socket set over 40 years ago. In the 80's I broke the 10mm and replaced it. But, it turns out I didn't have to. I had a spare. Only a couple months ago I discovered the socket labeled 9mm is really a 10mm socket. I had the perfect set all along.
