pugglewuggle
As an aircraft mechanic I need to remove rivets... a lot. This is done through drilling a hole in the center of the rivet head then gently prying the head off through the hole. A same-size drill bit or punch works great. I don’t want to use my nice punches for this task where it is easy to bend a nice long pin punch. What are the best super cheap pin punches that hold their edge and don’t round? Doesn’t actually need to be good when being hammered since this is done by hand. Once a punch rounds any more than a tiny amount, it is useless to me for this since the tolerance between the hole and punch is quite tight.
The goal here is to find a good punch for this that is so cheap I don’t mind bending it, dropping it, and eventually grinding it or throwing it away when it finally gets so bad it makes me mad... but it should last long for the mentioned task.
Go!
Sent from my iPad using Garage Journal
Go!
