Heating part of shop using a tent ?
ghlkal
Fredonia, WI
gtmedic
Southampton, NJ
I would recommend heavy construction plastic.
Had a friend that lived in their house while they were building it. First winter they made a 12x12 area around their wood stove. Stayed toasty inside the plastic...outside their bottled water would freeze.
finn
The UP, God's country
10’ wide would be really cramped to work in unless your project car is a King midget ,or maybe a Crosley.
Buy a couple of dozen 2x4 s and a roll of visqueen. Slap the walls up on 2’ centers, slip the plastic on top, and maybe use some 1”x2” to hold it in place.
Alternatively, I think some or the available storage tents are wider, albeit at a higher cost.
nadogail
Coronado, CA
Erecting a tent might be a viable temporary workaround.
I'm sure that others have found tents to be a pretty good "field expedient. Not pretty but effective.
Good luck.
G
ghlkal
Fredonia, WI
The tent arrived today, and we got it assembled and in place. Preliminary tests are positive :thumbup:
I won't have time to really work on the car for a few weeks, but I'll report back in after I do.
James-W
Southeastern Wisconsin
I think it is a very good idea if it is for temporary use. But if you plan on working on vehicles every Winter then I would think a more permanent solution would be in order.
G
ghlkal
Fredonia, WI
Yes, temporary. I'll see if I can really discipline myself to get out there and work. If so, I will look for a more permanent solution.
Bighead38
Rockland County NY
Just did gaskets and bearings in this 87. Not fun cars to do engine work.
