signcrafter
- Joined
- May 9, 2012
- Messages
- 12,504
Got my compressor into place and starting to put the pipe puzzle together. Compressor is a 3HP 30 gallon horizontal tank and weighs 325 pounds. I know it does vibrate a little when it's running but don't think too much. I have a 3/4" hydraulic hose that goes from my compressor to the piping on the wall so it's not a rigid connection and to give it some flexibility.
The compressor has "feet" that have a hole in each corner of the compressor. I'm thinking I want to put some kind of rubber like material under each foot and then anchor it to the concrete. I've never had a garage big enough to have a "permanent" compressor in my garage. Always just threw it wherever it would fit and used an air hose from it instead of piping.
First, is this a good idea? I can't really see any downside to doing it even if there isn't a ton of benefits unless I'm missing something?
Second, what is a good "rubber" type pad to put between the compressor and the concrete? I know they make special pads for this application but think they are pretty expensive. I've also read about people using hockey pucks. I found these googling last night that seem like they might work pretty good, https://www.google.com/shopping/pro...EtCbNPMI1NORq-pFxtvTP_zKpvsP70FcaAt44EALw_wcB. Anyone have these or something similar? They seem like they would accomplish what I'm wanting and they are cheap enough.
Last, what is the best anchor to use here? I'm not sure how thick the concrete is but it's a garage so guessing 3-4" thick most likely. I'm thinking some 3/8" drop in anchors would be good. Will allow me to unbolt it and slide it out of the way if ever needed. Only thing I'm worried about is drop in anchors don't really go in that deep. Just worried about if the top inch of concrete isn't strong for whatever reason and/or if the compressor vibrates too much and chips out the concrete where the anchors are. I don't think the compressor vibrates too much but I've never had one bolted down like this before.
Any other advice on bolting a compressor down?
