Ststephen7
Hey guys,
I've done some searching and I haven't found the answers... maybe because I'm not asking the right questions ; )
First, I'd like to "restore" this old grinder, and replace the original push button switch on the front. Are they still available, and it this a good idea? I couldn't post more pictures (although I have them) and the push button switch has 3 sets of screws, although only 1 pair had wires on them (and the wires had been cut).
Next... I am no electrician, and have never worked with 3 phase before, so the answers may be obvious for anyone familiar with 3 phase.
The wiring seems way more complicated than it needs to be (in my inexperienced mind at least). I have a total of 4 boxes, and 2 switches!?
I know I'll need a VFD (or RPC) when I have the $, and I'd like to clean up this mess if I can.
3 phase comes in the top, the next box down provides power out (left and right) for the lighting, and the bottom box has a switch (wired off the the left) and powers the motor through the back on the box and into the bottom of the motor.
Oh... and it there any reason why one light/glass shield housing would be marked 110 and the other 220? They both had the same bulbs (2 bulbs in each housing, just regular appliance bulbs). I have pictures of the wiring for each if needed (before I took them apart ; )
Wait, one last thing... are these mercury switches fine to put back in place? I'd like to keep it original if I can. They are in the light/glass shield housings, and probably turn the light on when tilted down, right?
Thank you!
Steve
Thank you!
Steve
