Towing into a garage.
cobia23
Cape Cod
That would be great, if the OP had room to pull it into the garage and then get the tow vehicle out. But, as stated in the original post...
I realize this is a moot point as the OP seems to have solved the problem, but why would he need room to pull the tow vehicle out, this bolts to the front of the of the TJ and the hitch goes on the newer wrangler, back it in the garage like a trailer. :headscrat
kbs2244
It is rare to work on a backed into a work bay vehicle.
Most work benches and tool boxes are across from the door and most work is under the hood at the front of the vehicle.
glider
Flint Michigan
My truck has a adjustable height hitch. It is a piece of billet aluminum with teeth. I have put a 2x wedged in and push many times. I use to move a lot of sheds around. But the tire thing is a good deal.
maxpower_hd
Massachusetts
Hmmm....I back into my garage often. I fingers I can back up almost to the wall and have more room in front. My bench is against the side wall. I guess I'm not normal.:wtf:
kbs2244
"Normal" is a state of mind.
Abnormal can be an advantage at times.
(All geniuses are abnormal)
I would say most GJ members are abnormal in that we do not consider a garage just a place to park the DD overnight.
Welcome to the club.
