shop apron,who still uses one,and what type/brand?
toplessHO
central florida
its been many years since Ive used a shop apron,but been thinking I should get back into the habit.
This would be for general shop use,not any one thing.
JiminAZ
Phoenix, AZ
I have a nice tan canvas one that I picked up from Brownells at one point or another. But around here it's so hot that I only use it in the cooler months.
Nice to slip it on to protect my clothes if I need to do something really quick. Otherwise I'm wearing a beater t-shirt and jeans that I can get dirty.
Shootinok
Oklahoma USA
I use one.
A couple years ago I splashed some leather dye on myself and decided I was on a quest for a manly apron.
After much searching (and trying not to spend a small fortune) I decided to modify my own.
I found a simple apron at Ace hardware in the BBQ section. But it wasn’t quite manly enough.
1st I melted beeswax in Linseed oil and coated it to make it into oilcloth (like they did in the old days). Then, I cut off the straps and attached a couple belts I got at goodwill for $3 each.
Sewed on some leather pockets and I use the heck out of it.
I’m thinking about modifying it again to change the strap configuration.
The single strap around the back of the neck puts weight on your neck.
I want to make them cross like an X on my back. Those type aprons I find more comfortable as all the weight is on your shoulders.
Sent from my iPad using The Garage Journal mobile app
frankush
IL
It kind of depends on what you're working with. For years I maintained tools for a large electrical contractor. Just about every tool was cleaned up, blown out and tested for operation before it got sent out to a job site. I usually wore some type of chemical apron that would keep the hydraulic fluid, cutting oil and grease off me. Lots of back and forth between the shop area and the office, so staying fairly clean was important. The few times I didn't put in on, always meant I was going to ruin clothes. I also like to wear one if I'm doing a bunch of cutting and grinding.
Wamsutta
Amarillo, Texas
The was a weldor in the shop that used to put a piece of foam pipe insulation around the neck strap; pretty smart. :)
rharman
SoCal
I have two from ShopSmith - 1 blue, 1 red.
Had a blue one. Went to a ShopSmith daylong seminar years ago. The guy asked "You know why we wear the red ones when we do demo's? So we can wipe the blood off a nick without freaking everyone out."
Miss the Pontiacs
Saskatchewan Canada
My daughter got me the Lee Valley canvas apron for Xmas. Haven’t had a chance to use it yet. Actually I could have used it a couple of times but forgot I owned one
:lol_hitti
tym
You guys are a bad influence--was just thinking about how I didn't like cleaning **** out of my clothes when I used my grinder.
Wound up ordering a Moonshine Leather apron.
ndnchf
Fredericksburg, Virginia
Non kidding, I used the $3.99 Harbor Freight denim aprons.
https://www.harborfreight.com/denim-apron-32306.html
The current aprons are a little different than the photo. Contrary to some of the reviews, the straps are long enough for big guys and they are sturdier than in the photo. I bought two a couple weeks ago and use them all the time. When it gets badly soiled, I'll just toss it and get another. Oh yeah, with the 20% coupon they are even cheaper.
jimreed2160
Tallahassee FL
I got one of those from HF after I caught my tee shirt on fire while grinding. It works well but does get a little hot in the summertime. I found a smaller apron for woodworking at HD.
https://www.homedepot.com/p/Husky-23-5-in-Canvas-Bib-Apron-Black-HD00122/300035090
ken w.
Western New York
I have a longer one from Brownells . I don't like wearing them , but its nice not getting all the **** on your cloths from buffing.
PartsGuy
Jamestown, NY
And this is precisely the same reason that the French Army wore brown pants in WWII.....:lol_hitti
El_Guapo
Globe, AZ
I've got a couple of Mechanix Wear aprons that I use when fooling with the cars. When I was still working in the shop, I had a heavy canvas one from Texas Canvas Wares.
Now that I'm usually driving a desk, I have a Red Kap shop coat for when I get too close to actual work.
joetech
Iowa
This darn forum. I just come here to browse and then I find another tool I must-have. Working in a tire shop and SO tired of my legs getting soaked every time I haul a tire out of the dunk tank and a shop apron would be the bees knees for that.
rlitman
Long Island
A rubber coated lab apron would be ideal. In fact, you could get one that just ties at the waist for that.
joetech
Iowa
Thank you for the suggestion, I'll check those out. Currently looking at waxed canvas aprons if I could find one that's set up like a Carhartt bib, that'd be ideal.
A lot of what I do is mechanic work, however I do need to do tires every now and then, and sometimes all day long. My usual wear is Carhartt black bib overalls unlined, however, I'm already on my second pair in about 3 months. The first pair is showing wear from tools and such, so I really do need to find something different that won't wear out so fast and doesn't need to be washed every day. I currently wash my bibs once a week. Just tired of picking up the tires out of the dunk tank and getting my legs wet. Granted, they do dry out fast, just a little annoyance. The boss wears Red Kap pants.
bwringer
Indianapolis
Same here. They're reasonably durable and cheap enough to keep a few around and toss 'em when they get nasty.
I guess I'd spring for something fancier if I had some more specific need and purpose, like leather if I did much welding or grinding.
Bodj Built
Moorpark, CA
A quality leather apron is worth its weight in gold. Not sure where mine is from, but it doesn't have any pockets, which I find perfect because it won't collect grinder dust. I keep my pocket knife in my jeans pocket, a tape measure clipped to the jeans pocket, and I clip a sharpie on the neck of the apron, so it's always there. The X back is a life saver, but I need to take some slack out of my waist strap, as it's definitely designed for big n' tall dudes.
ftb
Between UK and USA
Lincoln Electrics makes a welding one out of cowhide. No reason not to use it outside of welding applications. Quality item.
wimpy525
Catawissa, PA
Skiff Builder
Southern NJ Coast
Was given this Duluth for xmas. Seems well built. The lower middle pockets are a bit too deep and narrow. Hard to het hand in. The hammer loops are positioned so the handle of your hammer will beat your knees as you walk! I put another loop on the strap, works better.
Like the upper center hole for hanging on a nail.
Pocket with flap will not close over an Iphone.
Pretty good buit not perfect out of the box.
cderalow
Potomac, MD
I picked up a heavy canvas one from bed bath and beyond a while back.
Did the wax treatment to get it mostly liquid resistant.
Only has a chest pocket but the straps are extra long so it stays on well.
Gizmosity
SW Wisconsin
A few years ago I grabbed a close out Bucket Boss apron at a local hardware store for $5. My current shop is drastically larger than in the past so having some basics with me all the time really saved time. This lasted about 6 months but started wearing holes in the bottom of the pockets. I was thinking of having something custom made or even making my own, then I bought this:
https://www.amazon.com/gp/product/B000LBK7WO/?tag=atomicindus08-20
I've had it for two years and its close enough to what I would have spent drastically more money on that I plan on buying another one when this wears out.
joetech
Iowa
since this thread has been bumped back to the top I would like to report that I have now bought two red kap shop aprons. I haven't gotten my second one yet but it is absolutely awesome. I stay clean and dry while my apron gets all the grease and gets soaking wet. Has made a night and day difference at work.
T
toplessHO
central florida
I picked up a leather and a denim one at HF just to see if I still liked wearing one.
Welding without changing clothes is great.
The denim one is just for quick trips in and out of the shop while still in street clothes.
I really need to modify for X straps and maybe a plastic buckle thats easy to fasten from behind.
McFarmer
I got mine on Etsy, found a person making them and told them the size and location of pockets I wanted.
Be careful on Etsy and make sure you are dealing with a real live person, getting to be lots of promoted import junk.
Shootinok
Oklahoma USA
I liked this idea enough to try it.
I used a couple web straps with plastic buckles. Attached them to a well used HF leather with grommets I had from a tarp repair kit.
Went with crossing straps and it’s really nice.
Not fancy, but keeps me from burning holes in my clothes and maybe $20 in it.
