Ratcheting bit driver handles
signcrafter
I want to make my allen, torx, sets a little more complete. Instead of buying all the sets of T handles and then bits for 1/4" square drive for ratchets and then 1/4" hex drive for use with m12 driver. I'm thinking about just getting 1/4" hex drivers and then a straight and T ratcheting handle. That way I can use them with the ratcheting handles or my m12 driver. This will keep cost and the amount of space they take up in the tool box down. I'm thinking mostly the 6" long hex bits.
I do have some stuff already like metric long ball tip hex socket bits, long torx socket bits, and a ton of various hex bits. Just thinking that will be better to have interchangeable bits and handles vs buying complete sets of T handle and straight handle and all the others. Plus if a bit gets damaged or lost it won't cost much to replace.
Anyone go this route vs buying sets of T handles torx and allens?
I was looking for a good T handle and then start looking for sets of bits. Anyone have a good ratcheting T handle for 1/4" hex bits? I did come across this gearwrench set that looks pretty nice but looks like the handles are square drive and you have to use a extension that comes with it to get to 1/4" hex. I think I would like to be able to just stick the hex bits in the handle and not have an extra extension to have to use. But this kit does look pretty nice, https://www.amazon.com/dp/B000HBAHNC/?tag=atomicindus08-20
signcrafter
That Gearwrench set comes with 2 extensions that are for 1/4" hex bits.
Right that's what I said in my original post and I wasn't sure that would be a good thing that you have to use an extension and then your bit.
I guess I didn't really say it that good in my first post but my main want is a T handle and screwdriver handle to use with longer bits. I had been looking at T handle sets of torx and allen but they are expensive to get all the sets and then take up a lot of room. That is why I thought some ratcheting handles with some 6" long bits would make a better solution.
I have one of these, I haven't used it on anything super high torque but it seems halfway decent when I want ratcheting and extending action for a low price.
https://www.harborfreight.com/t-handle-ratcheting-screwdriver-61727.html
That actually looks like what I'm looking for. Not a huge fan of HF for things like this but might have to look into it next time I go to town.
El_Guapo
Globe, AZ
I use a ratcheting tap handle with torx bits quite a bit, because everyone keeps stealing my screwdriver handles.
If you want the best of the best in ratcheting bit drivers, it's Snapon by a mile. If you don't like the idea of paying $60 plus for a screwdriver, for about half the price you can get the exact same thing that says Williams.
https://www.amazon.com/dp/B001DNT68U/?tag=atomicindus08-20
If you buy used and happen to come across any 4" shank Williams T-handles that have a blue stripe on the shank and "Guapo" stamped in the handle, please beat the "owner" mercilessly and I will send a reward.
oldwino
Sonoma County California (wine country)
signcrafter
I'm liking that 2" one, thanks for the recommendation. I will probably buy new but if I come across yours I will be sure to let you know.
shirk
North Vancouver, BC
I was going down this same route with ratchet t-handle and screwdriver handle but now have decided to go with a 1/4" swivel head ratchet and a quick connect bit holder.
