Im turning my garage into a woodshop. and even with my lumber rack in the shop i need more space. so i am turning to my attic as the answer.
This is a picture of the trusses currently. they have a 55psf rating
the attic opening is between one truss dimensions are 22" x 36"
What i plan to do to make them stronger. Everything in white is stuff i added (i also enlarged the attic access to 36"x72"
On a side note where the trusses go over a non load bearing wall they float about 1/4 inch above that wall. can i use shims to make the trusses contact the wall to help with support?
