MaxJax With Wall Mounted Pump
TMXONR
Hi All, here are a few photos of my semi-permanent MaxJax install.
I installed the lift last summer and up until recently, every time I needed to use the lift, I had to wheel the pump cart out and hook up the hoses. The hoses were stiff and hard to work with. The hoses also got in the way of my welding cart and I always had a fear of weld spatter getting on the hoses.
I started to read around on how others were dealing with hoses that got in the way and found that a few people had mounted their pumps to the side of the column or to the wall. My only issue with the installs that I read about was that people were using hoses to run the full length. Running hoses entirely from the pump to the column can get really expensive. I was looking at over 300 for just the hose, so I made a call to a local hydraulics shop to see about building hard lines for the install. To go hard line, the tubing and fittings for this project were less than $120.
The parts used are:
2pcs male elbow - 3/8NPT to 3/8" JIC flare (connects between pump head and the hard lines)
2pcs female connector - 3/8" JIC flare to 3/8NPT (connects between the end of the hard line and the factory MaxJax hose)
1pcs union - 3/8" JIC flare (I could only haul 10ft sticks of tube, so I used these to connect the ends of the tubing together)
6pcs nuts and sleeves - 3/8" JIC flare (these are used at each hard line connection)
60ft seamless tubing - 3/8" X .065" (I only used about 30ft for this install)
Cable clamp - 3/8" (for mounting the hard line to the wall)
Rubber insulated cable clamp - 3/4" (for mounting the MaxJax hose to the wall)
As mentioned in the parts list, all fittings use a 37 degree flare. For this, you will need a flaring tool. I used a flaring tool that is similar to the Professional Flaring tool that Eastwood sells. This tool is a million times better than the cheapo vice units that gnaw up the sides of the tube. The hydraulic shop did give the option of using compression fittings but I went with the flares because they are better and I already had the tool to make the flares.
The hard line runs from the pump, up the wall, across the ceiling, and to the factory MaxJax hose. I decided to connect to the hoses, instead of straight to the column. This still allows me to take the columns down if needed. If I do need to move the columns, I can disconnect the hose and coil it up and out of the way.
I am very pleased with the install. The smaller ID of the hard lines doesn't seem to have had any effect on the lift or lower speed. My next steps are to get a jack-shaft garage door opener and maybe a high lift track conversion so I don't have to pull in backwards to use the lift.
rburke65
Canfield, Ohio
TMXONR....can’t see your photos as you need ..?..so many posts before you can add pictures. Since you joined in May of ‘15, and this is your first post, trust me, this is going to take you a loooooong while.
T
TMXONR
They were showing up on my computer. I went ahead and attached them to the post. You should at least be able to see the attachments now.
Jason280
That's a really clean install!
How long, in total, are your lines? I know MaxJax had told me there was a max length they suggested, somewhere around 30' or so, so I ended up mounting my pump on one of the columns (and then ran the lines overhead).
Can you tell any difference with lifting times with the longer lines?
T
TMXONR
Thanks!
The line for the column closest to the wall is approximately 25 feet from pump to cylinder. The line for the other column is about 8 feet longer. There is no noticable difference in lifting time with the longer lines. Also, both cylinders lift just as even as they did with just the equal length hoses.
Jason280
I originally wanted to do hard lines overhead, but had a buddy give me all the hydraulic hose and fittings for free...kind of hard to pass of that kind of a price. ;)
May Pop
Lake in the hills Il.
Nice clean install!
Now for the real question will you show more pics of the Cherokee?
Is that the frame from Action Fab?
Looks great!
JarcustomsLLC
Vancouver, WA
I have this same MX6 lift, and its been ok for since i had it install in December
I do have a question, and if you could post pics, even better...
Where did you lubricate? So far I have only lubricated the swing arms and the locking gear (to lock the arms in place)
I am not sure where else to lubricate? I was told there were rubber bushings, I can start to hear them now, but I have no idea where?
If you know and can take a pic, that would be super awesome!
I cant post pics yet, need a few more posts..
T
TMXONR
T
TMXONR
I lubricated inside of the channels of the column and on the lock mechanism.
JarcustomsLLC
Vancouver, WA
I just sprayed white lithium where I could
And I used synthetic grease in the channels using my fingers
Lifted both my bmw and Evo up no more weird binding noises ������
Wrightbenz
The parts used are:
Nice Job TMXONR. I was curious what the pressure of the maxjax system operated at. 3/8 tubing varies in pressure depending on the wall thickness so I’m not sure which 3/8 tubing I would need. I think the hoses are rated at 5000 psi but not certain.
