Dry Tool Bag Recommendation
hangfirew8
Central Maryland
Tonight I took care of something I've been dreading, went through every tool in my truck tool bag after it was exposed to water. Oh, last month I pulled out everything that looked rusty and took care of it immediately, sprayed Water Displacement formula 40 over the rest and left it under a 60W reading lamp. Today I finally went through it.
Results from best to worst-
  • All SK sockets, even the cheaper 1990's ones, came out fine.
  • SK 1/4" ratchet, spinner and extension fine
  • Old V Cman 3/8 extension fine
  • Cman/WF older 1990's screwdrivers came out fine
  • Cman metric wrench set early 2000's fine
  • Monkey Wards big water pump pliers fine
  • Bagged Cman ignition wrenches and crows feet fine
  • Very old SK 3/8 extension very slight rust on corners
  • Craftsman 1/4 and 3/8 sockets came out all over the map from fine to so-so
  • Craftsman USA pliers with raw metal finish had light rust
  • Irwin USA Vise Grips one very light rust one medium rust
  • All Black Oxide tools (brake tool, Torx Bits, nose of Cman ratchet) had lite to moderate to bad rust, brake tool was the worst
  • CMan/Western Forge adjustables rusted a lot
I had already cleaned up the brake tool and the worse Vise Grip. Below is a picture of everything else that rusted, everything good, and the bag.
So the circumstances. My Dakota had three rain leaks. One was the High Mount Rear Brake Light. Second was the gasket split at the bottom of each rear vent (a.k.a. rear side window). The other, harder to figure out, was the rear cab vents behind the rear passenger seats. They had been knocked inward by a bent bed and water was getting in there bad. The Cman bag soaked up water from the bottom on the carpet.
Interestingly the SK deeps were the only thing still wet when I pulled them out of the bottom, and they had zero rust.
I had fixed 2 leaks and thought I nailed it, put my tools back in then the rear vents got me with the worst flooding ever.
So my question, is there a good tool bag that is waterproof? The Cman bag was pretty much perfect in size, lots of internal and a few external pockets, it has held up for years. It is not one of their cheap 2/$12 promo bags. It has a nylon canvas type outer and a smooth plastic inside that could fool one into thinking it might be waterproof. But it sucked up water from the carpet it was sitting on.
Pictures in order- rusted tools, the bag, cleaned rusty tools, all the rest of the tools (including already cleaned up brake tool and vice grips).
ihateminimumwage
Worked outside out of service trucks and road boxes for a bit now, and while it's almost impossible to fully avoid surface rusting (especially on impact sockets) in that environment, I've found using the industrial carpet you can get by the foot at Home Depot soaked in WD-40 helps a lot as a box liner.
Even just a chunk of that lining the bottom of your bag should help keep things coated and push the moisture out.
tym
How about a box with a "Zerust" or similar vapor capsule inside?
H
hangfirew8
Central Maryland
Zerust is a possibility, I guess. A box is not.
The truck is a 2 door club cab, with a small rear bench seat. There is no trunk or bed mounted rear tool box. The back seat area is small. A bag fits in one side rear footwell behind the driver's seat OK, as long as the top is soft it's not hard on the single passenger on the other side.
A box, not so much. The hard corners tend to get the passengers on the legs and be uncomfortable. Maybe if it was the perfect size and not taller than the rear seat. A bag I can grab by just tilting the driver's seatback forward. A box I have to roll the driver's seat forward as well. But if you know of such a box, please link it and I'll check it out.
I could break up the bag and stuff it all into the under-seat cubbiess (the ones that became pools of water when the rear vents leaked). But then I couldn't grab-n-go with the tools.
A bag with a semi-rigid bottom might work. As long as it fit.
Wamsutta
Amarillo, Texas
Get yourself a bag made out of Cordura and ScotchGuard it.
I know tool bags made out of Dupont Cordura are hard to find, but they hold the ScotchGuard real well.
Backpacks are easy to find made out of Cordura.
poppakap
Northface Basecamp Duffel. Really tough. Its not marketed as waterproof but the laminated material is darn water resistant. Keep an eye out and you can get them at big discounts. I have one as a utility bag and its great.
samss
Conway, AR
My son has a green Stanley canvas tool bag with a plastic bottom. Not sure where he got it. The Milwaukee back pack I use has a plastic bottom for the very reason that I have to set it in wet locations.
Time to go shopping.
ChrisLS8
I just sprayed my DeWalt pro and Hercules bags with some waterproofing spray I got from HD
H
hangfirew8
Central Maryland
I can't find a green one, but searching for Stanley I came up with a real candidate, the Stanley 518150M. The plastic bottom would have been sufficient, as all the water was absorbed through the carpet.
https://www.amazon.com/dp/B000Q5PHGQ/?tag=atomicindus08-20
There is also a 14" version:
https://www.amazon.com/dp/B00J0K5KU6/?tag=atomicindus08-20
That's a great idea for the top of a bag with a waterproof bottom. Unlike the bottom which may sit in water, the top only needs to shed rain or a drip, not be submersible. I think I have a can of 3M ScotchGuard somewhere.
Why'd ya get it wet? Be more careful.
All the details are in my original post.
JBH
Would an L-BOXX fit?
Robinson1
Kentucky
In my experience any tool left on a truck will rust eventually. Especially stuff that's not used regularly.
I've worked out of service trucks for the past 15 years. Rust and moisture is always a problem. Doesn't matter how good of a box you have. Temperature changes will always cause condensation.
I've got a Leer commercial truck cap with tool boxes down the side. Damn thing was a greenhouse. It literally rained inside from condensation. Ended up insulating the whole thing with 3/4" foil faced foam board. It's taken care of 95% of the problem.
I've just came to accept that things like pipe wrenches and pry bars are going to have some surface rust. Smaller tools kept in bags are not as bad as the bag seems to offer an extra layer of insulation.
H
hangfirew8
Central Maryland
The problem with hard boxes is back seat passenger comfort. The current bag was a happy compromise on that point.
It looks like there are several choices of plastic bottomed, soft top tool bags. That would be sufficient if there is a reccurence of wet carpet. There is no rush on this, I will shop around and post when I find something.
Thanks for everyone's help.
-HF
rick carpenter
Huntsville, East Texas
If water leaking in on the floorboards is going to be a continuing problem, what about a thin plastic boxtop or similar as a 'spacer' then add a few 6x9 scotchbrite type pads?
H
hangfirew8
Central Maryland
Thank you everyone, for your suggestions.
I just ordered this, a WorkPro W081022A 16" bag. It has a hard plastic bottom that will probably crack in several years, but will prevent wicking up water in the mean time. There is a bright blue and black version for a few dollars less, but I'm looking for something that doesn't scream "I'm a tool bag, break the window and steal me". I will probably mark over the red stitching with a Sharpie for that reason.
I would have gotten the 13" but it has a fabric bottom. This will fit but I'm not sure if it'll sit flat on the floor. I guess nothing is perfect.
https://www.amazon.com/gp/product/B0109NETQS/?tag=atomicindus08-20
The 14" Stanley would have been a top contender but it's out of stock everywhere. The North Face looks really nice, but too pricey for my beer budget tastes, and I'm not currently an REI member.
I'll follow-up after I've used it a bit.
